20 Most Recent
HP LaserJet 2500 Printer Questions & Answers
Abc
Did you enable color printing in the printer properties. You may just have grey-scale enabled.
My HP color LaserJet 2500L printer will only print
Print cartridges might be improperly installed. Remove the print cartridge for the color that is
printing inconsistently and reinstall it.
im sure you tried this already, but thats from the manual.
also check your settings in the computer verify greyscale is not selected.
also. Re-calibrate anyway
To calibrate the printer from the HP Color LaserJet 2500 Toolbox
1 Open the HP Color LaserJet 2500 Toolbox in one of these ways:
• On the desktop, double-click the HP Color LaserJet 2500 Toolbox icon.
• On the Start menu, point to Programs, point to HP Color LaserJet 2500, and choose the
HP Color LaserJet 2500 Toolbox.
2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen).
3 Click Color Calibration.
Then try a test page.
if all else fails Try this
The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state.
The rotating drum in my HP Laserjet 2500L will not
listen to rotation, periodically/quickly open the lid while in rotation, make take a few attempts. i had this problem and powered it off after i "faked" the printer into doing what i needed, goodluck
HOW TO GET METER READING?
Switch it on and load paper.
Press the red and green buttons together, and several pages should print out, test page, config page, and perhaps a EIO or network config page.
The second page should show the page count.
Can not print
are you trying to print via the LAN if so goto the www.hp.com
web site and down load the latest network print driver, also make
sure your windows has the latest drivers installed, Hope this helps
"Install Cartridge" Error
Have you tried to clean the contacts on tonercartridges and the opposite HV contacts in printer? The contacts are on the left side of toner cartridges
Printing
It's a long shot, but there may be some paper stuck inside the toner cartridge. This happens occasionally. Be careful not to scratch the blue photo drum! Try replacing the cartridge.
