20 Most Recent
HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB 10/100 GL/2 HD- W/ LEGS C7780BABA HPHEWLETTPACKARD Printer Questions & Answers
Hp designjet 800 does not recognize black cartridge in ink supply station
I see lots of different posts- but not many that are actually helping-
Ffirstly are you using a original HP ink cartrige? ( 3rd party inks have IC chips that are usually not as robust as HP's, If- you've tried a Brand new Never inserted cartridge and still have the same error,you nedd to look at how the plotter recognises a cartridge, the IC chip (found at ink cart bottom) needs clean contacts check and clean the same for the opposite contacts in the plotter- wipe over with a alcohol wipe, allow to dry and try again, if it fails again I would suggest a replacement ISS ( ink Supply Station) a common failure on th Iss gives this exacting fault and may well be the cause, as above the ISS is a Service engineer fit,but can be handled by the customer if they are confident and thorough when following instruction, a ISS will likely cost about $200 so suggest you try cleaning the ink mist from the contacts first,
System error: 21:10 - Severe Error ox3010002 - task:tMech - file:sequence.c - line:758
Well this is an old post but my 2 cents anyway...Theres nothing to really fail on the service station besides the motor and that's highly unlikely.As a service tech I find that it gets gummed up with in and needs to be broken down and cleaned.Warning, there's lots of parts and lots of half dried ink, so expect to spend an hour getting it out of the machine and cleaning.
Hp Designjet 800 problem
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" try to download drivers from the website
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
