20 Most Recent HP DesignJet 1055cm InkJet Printer Questions & Answers
I'm sorry, but a 1050 is not fit to print double sided.
HP DesignJet... | Answered on Nov 29, 2017
The power supply is located in the back of the machine on the left hand side. It is part of the electronics module. It produces 24V, 5V, 3.3V and -15V.
HP DesignJet... | Answered on Mar 16, 2014
remove the net card completely and the cycle the power once it has come to ready print an internal print to ensure the fault lies external to the plotter , if it is able to print then the fault lies between the sender unit(PC) and the net card if you still have an error at this point the the Main PCA is at fault,
HP DesignJet... | Answered on Feb 12, 2014
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
HP DesignJet... | Answered on May 25, 2013
HP DesignJet 1055cm InkJet Printer Logo
52 questions posted
Ekse
Thomas F. Schneider
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
change pinter settings double sided in
  • Office Equipment & Supplies
