20 Most Recent HP LaserJet 4200tn Printer Questions & Answers
HP Laser Jet 4200 PCL 5 printer is printing a
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
3/10/2010 4:00:51 PM • HP LaserJet... • Answered on Mar 10, 2010
4200 SERIES WORKING FINE FROM THE COMPUTER AND
Have you tried a new toner? if yes, did you remove the entire plastic sealing strip before installing it? sometimes it can break and stay inside toner. if you did not pull out a strip of plastic about 14" long, you might need a new toner.
2/11/2010 8:53:13 PM • HP LaserJet... • Answered on Feb 11, 2010
HP 4200 PRINTER NOTABLE TO PRINT IN VISTA
Go to www.hp.com and let the website detect your printer and download the drivers automatically.
7/26/2009 7:55:13 PM • HP LaserJet... • Answered on Jul 26, 2009
Previous image repeats on next page
The problem is likely the fusing assm.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
3/24/2009 8:29:02 PM • HP LaserJet... • Answered on Mar 24, 2009
Network printer will not print
Hi Savo,
Is printer being recognized by network? What does device manager indicate? If there is a Yellow exclamation point, you need an updated driver. Try uninstalling software, removing access cable to printer and reinstalling software then re-connecting printer cable.
1/17/2009 9:53:03 PM • HP LaserJet... • Answered on Jan 17, 2009
Hp 4200 tn networking problems
I would suggest, print a diagnostic page from the printer, what IP address does it show? It is on the same network as your computers? If not then it will require changing the printer to either DHCP or giving it a static IP within the same range as your other workstations.
1/8/2009 9:57:59 PM • HP LaserJet... • Answered on Jan 08, 2009
We changed our internet service
Press the CHECK button. Scroll down to the I/O menu to change the IP address or use the JetDirect utility to make changes.
Right click on the printer icon in Control Panel and choose properties.
12/20/2008 1:32:57 AM • HP LaserJet... • Answered on Dec 20, 2008
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS. Question moved from 'Jet Office Equipment' category. It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply. Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ... My printer is displaying, "58.04 Error power outage detected... Jun 28, 2022 Laserjet Pro 400 MFP 451dn error message 58.04 Aug 5, 2013 My laser jet MFP M477fdw printer is showing 58.04 error cont... Sep 22, 2021 HP M451 Error 58.04 - HP Support Community - 5830295 Nov 1, 2016 More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1. ..
1/13/2024 5:59:42 AM • HP LaserJet... • Answered on Jan 13, 2024
13.B2.D3 laserjet 4555 mfp keeps happening
4/24/2023 5:38:52 PM • HP LaserJet... • Answered on Apr 24, 2023
LASERJET M1212NFMFP HAS A PROBLEM OF PRINTING BLANK IDONT WHERE THE PROBLEM IS
Checkthe laser unit shutter
1/28/2023 8:54:23 PM • HP LaserJet... • Answered on Jan 28, 2023
2answers
How solve hp laserjet P1108 error
11/21/2022 10:29:05 PM • HP LaserJet... • Answered on Nov 21, 2022
Hp laserjet p2035 Attention light is ON continuously
I thought your printer have a technical issue. After resetting the toner and restarting the printer, still printer light blinked continuously. That means the printer has some other technical issue. Find here the reasons and solutions to fix the HP Printer lights blinking error.
10/28/2022 8:41:17 AM • HP LaserJet... • Answered on Oct 28, 2022
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps: ·Turn off the printer ·Wait for 30 seconds and then turn on the printer ·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced ·In case the error is still being shown, the Scanner/Laser assembly may also require replacement. Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
9/23/2022 11:13:31 AM • HP LaserJet... • Answered on Sep 23, 2022
2answers
My Hp laserjet 600 m601 says 50.22.11 fuser error, how do I fix it
Replace the fuser assembly
9/20/2022 6:37:51 AM • HP LaserJet... • Answered on Sep 20, 2022
HP LaserJet pro color MFP M276N Network lan port no working
Troubleshoot the wired network connection Make sure you are using an undamaged Ethernet cable, check for a green light near the Ethernet port on the printer, and then print a report to verify the connection. Turn off the printer, and then disconnect the Ethernet cable from the router and the printer. Check the cable for damage, and then verify that it is an Ethernet cable and not a phone cable. NOTE: Ethernet and phone cables look similar, but Ethernet cables are usually bigger and have eight visible wires on the connector. Reconnect the cable to a different Ethernet or LAN port on the router, and then connect the other end to the printer's Ethernet port. Turn on the printer. Check the lights on the printer's Ethernet port to make sure the connection is successful. The green light should be steady, and the orange activity light should blink. Print a Wireless Network Test Results or Network Configuration report. Inkjet printers with a control panel menu: Open the Wireless, Network Settings, or Setup menu to locate the list of available reports. Most inkjet printers without a control panel menu: Press the Wireless and Information buttons at the same time, or press the Wireless and Start Copy Black buttons at the same time. LaserJet printers: Press and hold the Wireless button for 10 seconds or until the Ready light blinks, or go to the Wireless menu and select Wireless Network Test. Laser NS and Neverstop Laser printers: Press and hold the Resume and Wireless buttons for 3 seconds. DeskJet 6000 and 6400, ENVY 6000 and 6400, and Tango printers: Touch and hold the Information button until all control panel buttons light up, and then touch the Information and Resume buttons at the same time. Make sure the Network Status is Ready, or follow any instructions to resolve network issues identified on the report. Regards, Rachel Gomez
9/20/2022 6:31:08 AM • HP LaserJet... • Answered on Sep 20, 2022
3answers
How to clear memory on HP P3015
Before starting, note down the IP address if its network printer.. 1. Turn the product off. 2. Turn the product on. When the memory count begins, press and hold the OK button. Continue holding down the OK button until all three product control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. After the message SELECT LANGUAGE appears on the display, press the button or the button until COLD RESET is highlighted. 4. Press the OK button. The product performs a cold reset and then continues its power-on sequence. 5.Chk & set I/O settings..if required..
9/16/2022 8:54:41 PM • HP LaserJet... • Answered on Sep 16, 2022
Hi, I have a HP Laserjet P3005dn printer that gives a "13.20.00 jam inside rear bin" error message. Paper has been removed and problem still persists. Please help
After removing the paper jam, the issue has still persisted, then you need to check the printer drivers. Sometimes, when you remove the any stuck from printer. Then you need to check the printer drivers. Sometime outdated printer drivers may cause of paper jam issue. Read the following methods to fix the printer paper jam issue
9/5/2022 8:41:04 PM • HP LaserJet... • Answered on Sep 05, 2022
HP LaserJet 4200tn Printer Logo
10 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laser jet 4200 pcl 5 printer printing
  • Office Equipment & Supplies
