20 Most Recent HP LaserJet 2820 Printer Questions & Answers
2answers
HP 2820 printer stopped printing and gave a
This is a classic failure mode of HP Printers. I've tossed out two of them for the same reason, after fooling around for hours and wasting a couple of cartridges. My solution? Buy a different printer next time -- Canon, Brother, etc.
2/19/2018 10:34:29 PM • HP LaserJet 2820... • Answered on Feb 19, 2018
3answers
Have an HP 2820. The carousel on this will not
HI, Open the top cover of printer and try to clean up the carousel motor solenoid clutch. There are one foam tape - cean or better replace it. hp2820-oxw21mgdz5ogf1oadn2pd4nf-3-0.jpeg clean or better replace foam tape. (It is just for make less noise.) hp2820_2-oxw21mgdz5ogf1oadn2pd4nf-3-2.jpeg After that control carousel home position left and right gear home position marks must have same position. hp2820_aligned-oxw21mgdz5ogf1oadn2pd4nf-3-5.jpeg
4/29/2017 4:20:47 PM • HP LaserJet 2820... • Answered on Apr 29, 2017
3answers
HP 2840 : Error 59:99 T2 Clutch error
The problem you are having is with a clutch also known as CL2 or T2 Clutch. The part is available through HP at http//:partsurfer.hp.com. Just put in the part number RH7-5335-000CN and it will come right up for order. It cost 26.73 plus shipping.
The disassembly is a little intense but completely do-able with the service manual walking you through it. The clutch is part of the drive assembly on page 366 (#3). The diagram looks intimidating but its not as the full hunk can be taken off and then the clutch removed for replacement.
Here's a free copy of the manual:
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps you. If so hit it with a fixya!
2/11/2017 5:21:17 PM • HP LaserJet 2820... • Answered on Feb 11, 2017
My Hp 2820 machine is showing that the i need to replace new the black cartridge but when i chnged when cartridge the same massage is showing
I would suggest changing printers. That model was prone to many problems with that being one of them.
2/24/2015 9:16:23 PM • HP LaserJet 2820... • Answered on Feb 24, 2015
2answers
Black dots printing on right side of page
Have you tried a new Imaging drum?
12/16/2013 9:17:54 AM • HP LaserJet 2820... • Answered on Dec 16, 2013
HP Color Laserjet 2820 shuts off automatically
you may have to reinstall software. It seems something triggers it to shut off.
8/19/2013 2:52:50 PM • HP LaserJet 2820... • Answered on Aug 19, 2013
2820 error 2
Kevin_Trenow is correct with his solution to the HP colour Laserjet 2820 error code 5 problem - Thank you.The symptoms are that the machine turns on but after initial movement of the lighted up scanner, there is a disturbing ratcheting noise as if the scanner is trying to move but can't. The machine comes up with error 5 and suggests turning off and on again - this is a waste of time. 1. The top document feeder is released by detaching the multiplug and simply (carefully) removing the whole section.2. This allows the removal of 8(?) screws from the second layer which contains the glass platform. The screw heads were removed using a star drive, labelled CR-V T10. (Buy Draper 31 piece Precision Screwdriver and Bit set; part no. PSS31)3. Carefully lever off the grey surround with button labels on it - probably between 6 and 8 clips attach it.4. Now lift/gently lever off the glass containing layer.5. Use a spectacle wipe or erquivalent to wipe the glass over the white strip (This is the problem - the scanner light needs feedback from the white strip to end up in the correct position - the 'ratcheting noise is caused as the stepper motor continually moves the head to find the feedback point)NB. The glass above the white strip will look perfectly clean - looks can deceive!6. Replace the glass containing layer, ensuring it is clipped in - don't screw up yet in case more cleaning is required7. Turn on and the scanner light should end up in the required position.8. Replace screws, replace lid, push on grey panel and you should have a fully working machine for the price of a spectacle wipe.
1/26/2013 11:11:25 PM • HP LaserJet 2820... • Answered on Jan 26, 2013
0answers
Hp 2820 prints only on right side of page
Yes, you will need to replace the drum unit as well. be sure to shop around so you can get the best price because some people mark up the price for that part. You can check the status of your supplies from the printer itself by pushing the "menu" button the printer and scrolling through until you see something about supplies status then press the check mark button.
5/16/2012 8:50:34 AM • HP LaserJet 2820... • Answered on May 16, 2012
0answers
Says "replace supply using black only" yet all
Refix connector J127 on dc, clean the supply memory contact,switch on the machine remove all supplies, install one by one, check the recognition of supply status, missing all? replace DC controller, only black missing?Replace with another one,check, remain same, observe cartridge seated properly? compare with another cartridge feels difference? check the supply memory properly connecting to the contacts?..any breakage in corosol unit?..replace the corosol..
10/6/2011 6:02:55 AM • HP LaserJet 2820... • Answered on Oct 06, 2011
Hello, I have a 2820
Do NVRAM Initialization for factory default setting. Press & hold enter & * button then turn on the printer, wait till "permanent storage init" appears on display then release the buttons, wait till ready mode comes, check.. I hope it will help you.. But..all setting you will lost like fax,copy,phone book.. be care full.. Best of luck..
9/23/2011 6:10:25 AM • HP LaserJet 2820... • Answered on Sep 23, 2011
Printer only prints on left
Other than tec guy are not advisable to do this exercise :Corosol align distrubed,open the printer up to corosol mechanism check rotary swing shoft left and right gears, there are markings which was exatly matching with rotary right & left disc markings. If its distrubed print quality issue will comes.
You are facing the same complaint. Before opening the machine ensure that read carefully service manual hp clj 2820/2840.. Best of luck.
9/7/2011 5:08:51 PM • HP LaserJet 2820... • Answered on Sep 07, 2011
HP LaserJet 2820 Printer Logo
122 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
says replace supply using black only
  • Office Equipment & Supplies
