20 Most Recent
HP Officejet 4110 All-In-One InkJet Printer Questions & Answers
Can I reprint a fax that I just received?
If you want to reprint a fax because the print cartridge was empty or if the fax was printed on the wrong type of media, you can try to reprint it. The amount of memory that is available determines the actual number of faxes that are stored for reprinting. ... These faxes are stored continuously.
here's how if you have this accessibility..
Press "Setup" on the control panel of your fax machine. Most fax machines will have an LED display panel on the front of the machine. The panel will usually include on screen prompts and help options. Some fax machines signal the user if they have faxes stored in memory and prompt the user to "print faxes" or "clear memory," but you need to make sure that you don't accidentally clear the memory or you will lose all saved faxes.
Use the arrow keys or number pad as directed by screen prompts to select "Fax Setup Menu" and then press the "OK" or "Start" key.
Enter the security code, PIN, or user authorization code if required. The security code or PIN protects sensitive information and prevents unauthorized use of the fax machine memory. If you haven't set it up you don't have it.
Navigate to "Receive" or "Print Faxes in Memory" and then press the "OK" or "Start" key as directed by the on-screen prompt. The last fax stored in the machine's memory should begin to print.
Repeat the above steps for each fax in memory if you need a different one.
Hope this helps and isn't clear as mud!
Happy new year.
problem? make and model # please.
Paper
first unplug power cord without turn off then insert power cord and check
if steal showing ur problem
check paper load motor
How do i make it my default printer
HiBy right clicking on the printer's icon and select on 'set as default printer'.If not installed,be sure to set it during setup installations.The 'set printer as the default printer' will appear before full installation.
How do i change the language in my hp printer
If you have the disk it may be as easy just to uninstall and go through the install process again i know some printers not sure on your specifically have more then one install disk and only certain languages on each disk
My printer say out of paper
Hi,Turn printer off and on.Check to see if there is a print queue and then load the papers to end the printing.Try also turning the printer off and unplugging it from power and restarting your PC.Plug printer back and connect with the PC and then turn them on.You can also check for paper jams in the paper paths and manually remove any stuck papers.Run a print test by:
- Press setup on the printer menu
- press 1 and then press 4
- Press start color/start black.
- Your officejet now runs a print test.
Hope this helps.Thanks!Please rate this answer.
Please help me.
Yes, kindly state your issue. I'll love you help you out.
Concerned, Nooh
A black line the full
For this problem Clean the printing head 2-3 times and check the nozzles. Check also the cartridge ink level. Or you have to replace the print head.
The ink is dried up
If both of both of the cartridge has dried up, I suggest you replace them both to prevent further problems to your printer. If you are planning to print just black from your printer, It is still advisable to use a working color cartridge as a clogged one can cause cartridge detection problems which may result to further printing issues.
Click
here to view an article on how to clear a clogged cartridge.
