20 Most Recent
HP LaserJet 6mp Printer Questions & Answers
I get a dark streak
It is either toner cartridge or fuser.
Print a few sheets of anything.
While printing, open the cover and pull out the toner.
Look down at the paper. If you see a dark streak, you have to replace the toner.
If the page is streakless, replace the fuser.
Printout is less toner and
As with most HP LaserJet printers, any problem like this, usually points to the FUSER. The FUSER ensures the toner is "fused" to the paper.
I have a laserjet printer 6mp and i have tried
I finally got my LaserJet 6P to work with Snow Leopard - after about a year of it not working
Using a generic USB to Parallel Connector
Thought I had tried this before but apparently not
Went into the Printer Driver and instead of selecting the already recognized HP 6P Driver, I selected
Generic PCL Laser Printer
And then checked off the Duplex Box
Works likes a charm
Amazing
I have a HP 6MP
Can't be positive without hearing and seeing myself but the main motor makes a terrible sound whrn the gear on it cracks or it locks up. The jamming could also be because a piece of paper is jammed under the paper guide directly underneath the toner cartridge. If you look down in the machine you will see one silver screw on the left side, that is all you need to remove to take out the guide.
A thin vertical line appears on the page as it is
9 times out of 10 any kind of dark or blank line on these HP's is caused by the toner cartridge. Hopefully you have a spare you can swap it out. Even an old one will do as a test to see if the line goes away. The only other possiblity would be fuser film problem, but my money is on the toner cartridge.
Good Luck and Thank You for using Fixya.
Installing ink cartridge in hp laserjet 6mp
I am not sure what you asking here but you need to press a button on the right hand side printer to open the top cover and then you have access to remove the toner cartridge.
Hp printer only printing half page
Hello Rajodawson,
There are few things that makes the HP printers only print half of the page.
-- HP printer is loosing connection while you are printing the page .
-- The driver is damaged and old so you should upgrade the drivers from the below link --
CLICK HERE TO DOWNLOAD
make sure you have enough HDD space, and RAM. It's usually a spooler issue relating to contiguous disk space available for spooling the file. It could also be the result of old files left in the spooler folder.
If the laptop has only ONE hd partition, what may well be happening is that while the software's scratch file is large, you don't have enough contiguous free space left to spool the output completely. That could cause the problem you describe as well..
Also last but not least take out cartridge and shake it so if the ink is jamed it will clear that.
Please let me know if you have any further questions or concerns.
Thanks.
HP laserjet 6mp mac
Most likely to be a driver issue. Try downloading from the following.
www.hp.com
www.hp.co.uk
or there maybe a small charge for downloads
www.drivers.com
Thanks J
