20 Most Recent HP OfficeJet 9120 All-In-One InkJet Printer Questions & Answers
Hp officejet 9120 won't power down but won't print either, it seems to be locked up, display just shows dots scrolling right to left
Unplug your printer from the outlet for several minutes and repower it back up. I have had this with my printer and usually solves the problem.
1/2/2012 8:21:07 PM • HP OfficeJet... • Answered on Jan 02, 2012
OfficeJet 9120 All-In-One InkJet Printer: hello The fax in my hp officejet 9120 is not w...
According to the manual found at support.hp.com, you need to go into the setup menu for faxing and enter the necessary information prior to faxing.
3/11/2011 4:35:32 PM • HP OfficeJet... • Answered on Mar 11, 2011
The error message is saying
If you opened the lid in the same manner as you would to replace the ink cartridges and made sure that the switch on the right side underneath the lid was in fact unlocked, turned off the unit, waited a moment (up to 60 seconds) and turned the unit back on, but still receive the message saying that your scanner is locked, then you will need to use a Phillips screwdriver to remove the top cover and make sure that the scanner head is not somehow jammed. Usually you can hear the gears and motor spin up when the scanner head is unlocked. If you cannot, you may have a bad scanner head.
3/11/2011 4:34:30 PM • HP OfficeJet... • Answered on Mar 11, 2011
Keeps showing empty cartridges (they are not)
The jets are clogged. You will either need to replace them or take them out and clean them with alcohol or WD40 and a long cotton swab.
3/11/2011 4:32:05 PM • HP OfficeJet... • Answered on Mar 11, 2011
Printer will not scan ( says scanner locked) it is
Open the latch on the front of the unit above where the paper comes out, underneath the lid on the right side is an orange switch. Flip the switch, turn off the until, wait about a minute and turn it back on. The scanner is physically locked by this switch. I believe the proper position for unlocking is towards the front of the unit, but the diagram is underneath the lid next to this orange switch.
3/11/2011 4:30:09 PM • HP OfficeJet... • Answered on Mar 11, 2011
How to change the toner
This unit does not use toner. It uses ink cartridges, hence it is called an OfficeJET All-in-One INKJET Printer. To change the ink cartridges, you lift the latch located on the front of the unit above where the paper comes out.
3/11/2011 3:44:21 PM • HP OfficeJet... • Answered on Mar 11, 2011
Please Send Me HP Officejet
I do not know your operating system, therefore I leave you to this HP Support page ::
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&tool=&query=HP%20Officejet%209120&product=376174&
3/11/2011 3:42:39 PM • HP OfficeJet... • Answered on Mar 11, 2011
We are unable to print
The jet is clogged in the ink tray. Use alcohol or WD40 with a long Q-tip to clean out the clog.
3/11/2011 3:39:34 PM • HP OfficeJet... • Answered on Mar 11, 2011
Black, cyan, Magenta, yellow ink cartridges
You can refill it for 1 time use other wise give to hp people for recycling.
1/28/2010 7:11:22 AM • HP OfficeJet... • Answered on Jan 28, 2010
How can i open the hp officejet 9120 in order to
Get the manual from this site and read th einstructions about setting up.
http://www.retrevo.com/support/HP-9120-Multifunction-Printers-manual/id/260ag504/t/2/
Hope this will work for you
Have a good day
luciana44
12/3/2009 10:37:22 AM • HP OfficeJet... • Answered on Dec 03, 2009
Unable to print on HP officejet 9120. Error ; Load
when you give print command go to print properties and choose the paper size as well as the tray to print aslo in printer set the the size or paper in tray.
11/20/2009 9:57:48 AM • HP OfficeJet... • Answered on Nov 20, 2009
Despite having used all of the service and
It is the print head that needs to be clean manually or should be replaced. If you can't do it then bring the printer to the printer repair center or in the computer repair center in your place.
10/29/2009 1:51:14 PM • HP OfficeJet... • Answered on Oct 29, 2009
HP 9120 Constantly aligning printheads
hi thanks for using fixya!
I recommend that you should replace the printheads to anew one. And you have replace the color ink cartridges as well. If you have used an exprired cartridges, it will result an error to your printhead. Always make sure that you always change the ink cartridges whenever it is required and if you are frequently using it heavily. Backdating the machine is helpful, however it will be more efficiently if you replace the printheads. By the way, how many years now your are using your HP printer? Did you had a chance to send it to any HP Service Center for maintenance as well? I recommend to my clients if they are heavily using or not the machine, it should be always be maintained every 6 months.
If you need further assistance, let me know.
5/15/2009 5:06:04 PM • HP OfficeJet... • Answered on May 15, 2009
2answers
I am getting a scanning error. Scanner not responding.
Does the error show up on PRINTS FROM YOUR COMPUTER also, or only when SCANNING A DOCUMENT? If the line is only from scanned documents, the SCAN GLASS has something stuck on it. The SCAN GLASS is a GLASS ==> located under the ORIGINAL FEEDER. It is NOT the plate of glass you place the original on . Look UNDER the original feeder for a scrap of paper stuck in the optical path of the GLASS ****, and remove the scrap, or CLEAN THE SCAN GLASS IF CORRECTION FLUID, INK, ETC ARE STUCK ON IT. If the line shows up on ALL prints, your CHARGE CLEANING SLIDER located in the IMAGING (DRUM) UNIT must be slid all the way to one end of the charger, OR IT WILL CAUSE A BLACK LINE ON ALL PRINTS. Otherwise, the IMAGING UNIT may need to be cleaned or replaced. Toner smudges on the drum would indicate need for cleaning or replacement.
Sounds like you have a glitch in the main logic board of the printer when it prints the axial location buffer is loaded either with junk or isn't functional and sees nothing but blank data in that location. Try resetting the printer consult manual/mfg for reset codes? Thanks Have a nice day.
4/28/2009 12:10:16 AM • HP OfficeJet... • Answered on Apr 28, 2009
Looking for Hp 9120 driver for Mac OsX.4 thanks!
Here the driver download page: HP Officejet 9120 All-in-One Printer.
Do not forget to rate the solution.
Many thanks.
3/1/2009 4:45:24 PM • HP OfficeJet... • Answered on Mar 01, 2009
HP Officejet 9120 all in one
i want free download hp officejet 9120 printer drivers what a i do??
12/4/2008 1:21:09 PM • HP OfficeJet... • Answered on Dec 04, 2008
2answers
CHANGE CARTRIDGE
how to change cartridge of my hp deskjet 380
8/12/2008 10:37:16 AM • HP OfficeJet... • Answered on Aug 12, 2008
2answers
Printer/Scanner Problems
Does the line show up on PRINTS FROM YOUR COMPUTER also, or only when SCANNING A DOCUMENT? If the line is only from scanned documents, the SCAN GLASS has something stuck on it. The SCAN GLASS is a GLASS **** located under the ORIGINAL FEEDER. It is NOT the plate of glass you place the original on . Look UNDER the original feeder for a scrap of paper stuck in the optical path of the GLASS ****, and remove the scrap, or CLEAN THE SCAN GLASS IF CORRECTION FLUID, INK, ETC ARE STUCK ON IT. If the line shows up on ALL prints, your CHARGE CLEANING SLIDER located in the IMAGING (DRUM) UNIT must be slid all the way to one end of the charger, OR IT WILL CAUSE A BLACK LINE ON ALL PRINTS. Otherwise, the IMAGING UNIT may need to be cleaned or replaced. Toner smudges on the drum would indicate need for cleaning or replacement.
8/12/2008 8:16:17 AM • HP OfficeJet... • Answered on Aug 12, 2008
HP OfficeJet 9120 All-In-One InkJet Printer Logo
28 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
black cyan magenta yellow ink
  • Office Equipment & Supplies
