20 Most Recent
HP DeskJet 6127 InkJet Printer Questions & Answers
Replaced color cartridge in deskjet 6127. printer
Try cleaning those contact points on the cartidges(looks like gold dots). You can use nails polish remover or surgical spirits. If it's still not working then you should take it to yur nearest dealer for service or repair.
NOT PRINTING BLUE INK
Sounds like the cyan print head is clogged or you are out of cyan ink. You can try running cleaning cycles with your printer or you can try to clean the print head yourself. To clean it yourself you will need dry paper towels and papers towels moistened with warm water. First rub the print head with the wet paper towel, then press the cartridge into the dry paper towel to see the three color bars (a good print head will have three solid fat color bars). Then you can try resting the print head on the wet paper towel for about a minute to get the ink to flow out (do this on a surface that you don't care about, ink stains). Then rub and blot the print head on the dry paper towel. Continue until the cyan flows again (if after 2-3 tries it isn't flowing you probably won't get it flowing). If you go to a Cartridge World store they have equipment to get print heads flowing again and they should clean it for you.
I lost my cd to install my hp deskjet 6127 printer
Hi...
To download a driver of your printer you can visit the site of hp.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=86858&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Use the lick that i can provide after that it will required you to selst if waht type of operating system did you use.
Regards
PCmania
It won't print
go to start>programs>control panel click on printers and faxes, is there more than one printer that shows up? is one of them checked?
I have constant blinking cartridge light on my hp
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
The same here
hi there i will help you first what you need to do is get a screw driver open the printer up strip it down then get to the cartrage then u shuld beable to deal with that then put the case and everything back in aprt from the cartrage then when you have done that u need to put the cartrage back in it should pop back in just means one of the termimnal are making lights flash about if you need anymore hel p let me know
[email protected]
All three lights are flashing
Hi
The HP Deskjet 6127 has four buttons and three lights on the front panel
Flashing lights on the printer indicate the status of the printer
When all the lights are flashing, the printer may need to be restarted
try this 1st press the power button to turn off the printer, and then press the power button to it back on very quickly.
2nd press the power button to turn off the printer and hold it down.
Good luck
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
