20 Most Recent Smeg Repair Pcb / Module Dw1612 Dwi612c Questions & Answers
Smeg dishwasher won't stop washing
I have exactly the same problem, were you able to find a solution? Thx
7/11/2022 6:16:23 PM • Smeg Repair Pcb... • Answered on Jul 11, 2022
I found PCBs in soil at concentrations <25 ppm from an old release. May I move this soil freely on-site? May I move it to another site? May I use it as fill?
You'll have to ask your local county authorities or the EPA for the correct answers. Until you get them,I wouldn't mess with PCB-contaminated soil.
10/7/2016 7:15:53 AM • Smeg Repair Pcb... • Answered on Oct 07, 2016
Are air compressors and air tanks that are contaminated with PCBs <50 ppm regulated for use?
PCBs in air compressor systems are authorized for use at concentrations <50 ppm. http://www.qjpcb.com/ whatsapp:+8618688621379 http://www.qjpcb.com/
10/7/2016 6:40:21 AM • Smeg Repair Pcb... • Answered on Oct 07, 2016
Is notification to EPA for PCB research and development under §761.30(j) still required?
No, notification to EPA is not required under §761.30(j). However, notification is required for research and development for PCB disposa http://www.qjpcb.com/ whatsapp:+8618688621379 http://www.qjpcb.com/ Skype : wang.michelle35
10/6/2016 9:08:16 AM • Smeg Repair Pcb... • Answered on Oct 06, 2016
2answers
How do the assumptions fit in with the Spill Cleanup Policy?
For purposes of the Spill Cleanup Policy only, where a spill of untested mineral oil occurs, the oil is presumed to contain >50 but <500 ppm PCBs. (See the definition of "spill" at §761.123.) No other assumptions or presumptions apply to spilled liquids.
9/14/2016 11:37:26 AM • Smeg Repair Pcb... • Answered on Sep 14, 2016
If a spill occurs from equipment assumed to be PCB-Contaminated, can I assume that the spilled liquid contains a PCB concentration of 50 and <500 ppm?
No. The PCB concentration assumptions apply only to equipment while in use, not to material spilled or otherwise released from the equipment.
9/14/2016 11:31:54 AM • Smeg Repair Pcb... • Answered on Sep 14, 2016
How do PCBs get into natural gas pipelines?
Polychlorinated biphenyls, banned in the U.S. since 1979. Some residue is probably still in there. Printed Circuit Board (PCB) is something totally different.
9/8/2016 5:49:20 AM • Smeg Repair Pcb... • Answered on Sep 08, 2016
2answers
Does the 10,000 ppm limit apply to each sample that I use in a treatability study?
Yes, the limit applies to each individual sample that you use. No single sample may exceed a concentration of 10,000 ppm PCBs. http://www.qjpcb.com/ Skype : wang.michelle35
9/1/2016 6:31:37 AM • Smeg Repair Pcb... • Answered on Sep 01, 2016
2answers
Sources of PCBs in Natural Gas Sector: PCBs are most likely to be found in equipment associated with the processing of the natural gas (Phase 3). For example, old transformers and capacitors, other electrical equipment including voltage regulators, switches, reclosers, bushings, and electromagnets, oil used in motors and hydraulic systems at gas processing plants. In addition, major interstate natural gas pipelines transport natural gas from production areas to local distribution companies (LDCs) that distribute the natural gas to industrial and urban customers. PCBs were used in turbine and air compressors as a hydraulic/lubricant and a plug valve sealant by some large interstate natural gas transmission pipeline companies and by some smaller LDCs. Some interstate pipeline companies may also have had PCB transformers and/or PCB capacitors at large compressor stations and/or maintenance facilities. Similarly, old gathering lines, which move gas from the well/well field to the gas processing plants, might also have compression stations that contain legacy PCBs.
8/3/2016 8:32:48 AM • Smeg Repair Pcb... • Answered on Aug 03, 2016
May I store PCB Articles indefinitely for reuse in a facility that qualifies for interim status under section 3005 of RCRA?
Didnt specify where you live --notify the regional area EPA for proper forms , directions and facility for proper disposal the following link is for EPA --- PCB storage and disposal Disposal and Storage of Polychlorinated Biphenyl PCB Waste Polychlorinated...
7/27/2016 1:14:42 PM • Smeg Repair Pcb... • Answered on Jul 27, 2016
If I test a transformer for disposal and find that it contains PCBs in concentrations 500 ppm, must I register the transformer?
didnt specify where you live --notify the regional area EPA for proper forms , directions and facility for proper disposal the following link is for EPA --- PCB storage and disposal Disposal and Storage of Polychlorinated Biphenyl PCB Waste Polychlorinated...
7/27/2016 1:08:56 PM • Smeg Repair Pcb... • Answered on Jul 27, 2016
Smeg Repair Pcb / Module Dw1612 Dwi612c Logo
44 questions posted
Top Smeg Dishwashers Experts
Mike Cairns
Mike Cairns
Stan Ford
Tracy
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Smeg Dishwashers
  • Smeg Dishwashers
Most Popular Question
smeg dishwasher won 39 t stop washing
  • Dishwashers
