20 Most Recent
Rosetta Stone Spanish Spain Level I & II Set Personal Edition (esclspe) Questions & Answers
How do I remove the lock on the lessons?
I am sorry but FixYa does not provide that type of information
You must contact The software supplier directly
Sorry about that
We could always forward them your request using the email account and IP address of your computer that you use to access FixYa if that will be of use to you so that they can contact you directly if you wish.
They do take credit card payments
Richard Scott
After uploading the application software for
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder
"ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it
to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the
Rosetta Stone install directory, run the "service_installer" .exe file
by double-clicking it.
Extract RSD files
Files that contain the .rsd file extension are normally associated with
the RealSQLDatabase. The RSD file format that associated with this file
type is a database file format that is used by the REALbasic software
application. The REALbasic software program is an application
that is used to develop other software applications that use the BASIC
programming language. These RSD files store the database information in a
structured format. The information contained in the database can then
be accessed using the various SQL commands. The .rsd file
extension is also used with Roland software program. These RSD files
store sound files that are used by the application. Or in simple terms you need the right software to use a RSD file.
I am getting a Rosetta
First have you tried uninstalling it and reinstalling it and see if that helps the issue at all? Also is your OS up to date? Once I have more information I can assist you further.
Thank you,
Lee
