20 Most Recent
HP Scanjet 4200c Flatbed Scanner Questions & Answers
IS IT POSSIBLE TO SCAN TEXT TO TEXT? THANK YOU
You need a OCR (Optical Character Recognition) program to convert your scanned text pages (which are images) to text.
You printer software doesn't include such a program.
There are a number of commercial programs available -- I.R.I.S, ReadIris, Abbyy Fine Reader, Adobe Acrobat (not the free Acrobat Reader), just to mention a few -- and also some free programs (SimpleOCR came first in a Google search).
Also, some computers also come with a limited version of these programs installed. I have an HP that came with a version of Readiris
I bougth a used hp
Hi ,Im sure it came with a cd to install the sotware , so insert into your cd rom and click install ,if this does'nt work , let me know ...................Roy
The belt inside my scanjet 4200c has come off.
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
I have a power source
Line Voltage
100-120VAC 60Hz
100-240VAC 50-60Hz
200-240VAC 50-60Hz
I read the above at the hp.com website on the electrical specifications section of the specifications page.
