20 Most Recent
GE Profile Spacemaker 2.0 Cu. Ft. Over-the-RanMicrowave Oven Questions & Answers
JVM1860WF001 - Was cooking soup
SOUNDS LIKE FLAME SENSOR SWITCH OPENED OR CLOSED AND THE UNIT THINKS IT OVERHEATED AND TURNED THE FAN ON TO COOL IT MUST FIND SHORTED FAN SWITCH
How can I check the diode?
It normally is not possible to check the diode of a Microwave oven without some special high voltage testing equipment. If you suspect it, replacing it would be much cheaper. A typical DVM will not do the job. But diodes usually are not the first part to fail; check the transformer.
Microwave is Locked please advise on how to unlock.
Since I don't know the model, here's a general answer. On a GE over the range oven, the top air deflector assembly is usually removable. After its off, you will have access to the fasteners at the top of the control panel. Remove it, and you should be able to see the door switch/latch assembly on the left.
Do all of this with the oven unplugged. Do not go near the high voltage capacitor as it can retain a charge of 4000 volts indefinitely. Stay away from the rest of the h v wiring as well. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/david_29ad5d1dd86564b0
JUST STOP WORKING NO POWER.
There is a fuse inside the unit you may check and see if that is it. If not then it will be the front panel. Hope this helps
