20 Most Recent HP Pavilion d4100y (PX181AV) PC Desktop Questions & Answers
Sounds like you lost your drivers..reinstall Windows drivers and operating software as well if needed
HP Pavilion... | Answered on Jul 22, 2017
Hi Bob.
You will have to take the side panel off the computer and check that the power cable is connected to the DVD/RW, if it is and you have no LED indicators or the tray won't open it is a strong possibility that that the drive itself has failed and you will need to replace it with a new one. Optical drives are very cheap these days not costing much over 20 dollars or 10 pounds. DVD optical drives are plug and play so the operating system will already have the drivers preinstalled.
Regards.
HP Pavilion... | Answered on Feb 04, 2013
If you have the speaker/headset connected to the right port and still don't have any sound. It may be the sound driver. What you can do is to download and install the sound driver for your computer. I'm not sure what is the operating system of the computer that you have.
For windows XP, you can click on this link to download the driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-39525-1&lc=en&dlc=en&cc=us&os=228&product=500981&sw_lang=
All other driver for other OS, click on this link and choose your OS.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=500981#N152
That will work. I'll appreciate the comment or thumbs up.. :D
HP Pavilion... | Answered on Apr 26, 2011
Access the Recovery Console and extract a new copy of the Kernel32.dll file from the original WinXP CD
1. Start recovery console as described above
2. Insert the WinXP CD
3. At the command prompt, type CD system32, press ENTER
4. Type ren kernel32.dll kernel32.old, press ENTER
5. Type map, press ENTER
6. Go to the drive that contains your CD
7. Type expand drive\i386\kernel32.dl_, press ENTER; Kernel32.dll should be listed as 1 file expanded
8. Type exit, the computer restarts
9. Remove the WinXP CD
HP Pavilion... | Answered on Apr 11, 2011
Do you have wireless on your desktop? Also, it might be a PCI card (meaning no real switch) if you have wireless on your PC.
If this is not the solution you are looking, write back.
HP Pavilion... | Answered on Jan 15, 2011
reinstall your PC's sound drivers using the drivers disk which came with the PC.
Alternatively, go to the HP website and use their automatic update service to update and reinstall your sound drivers. www.hp.com/support
If reinstalling the sound drivers fails, you may have a logic fault with your sound system, take the PC to a professional for this as this is part of the mainboard.
HP Pavilion... | Answered on Jan 14, 2011
Stop turning it on and take to repair center you might damage more of the components and loose data
HP Pavilion... | Answered on Aug 04, 2010
Just do a Google search for windows xp disc and you'll get results similar to this
http://www.google.co.uk/products/catalog?q=windows+xp+disc&oe=utf-8&rls=org.mozilla:en-GB:official&client=firefox-a&um=1&ie=UTF-8&cid=11969216369837725015&ei=VE5LTMLoMZn40wSCr6CFCw&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDgQ8wIwAg#
HP Pavilion... | Answered on Jul 24, 2010
yes you are right. i believed problem is monitor, the display vertical 7pins IC some of pins is weak, need to resudder by reheating using solder iron. and second, try replace video card.
HP Pavilion... | Answered on Oct 12, 2009
There may be no problem here. Has it always done this? Usually when executing some major tasks the CPU gets hotter and sends a signal that it requires the fans to work harder to keep from overheating. This may be normal.
hope this helps!
HP Pavilion... | Answered on Aug 14, 2008
in your android phone's settings enable or access developer options and turn on usb debugging,( if you don't know how to access developer options you can google your android phones model and android version and how to enable usb debugging) once you enable it just plug it into your laptop and it should recognize it and automatically download the correct driver, if not, go to your phones manufacture's website and look for driver downloads for your model and android version. you can also google this to save time.
HP Pavilion... | Answered on Dec 31, 2019
A DVD player that is an integral part of the laptop does not need drivers to make it play discs. If there is no driver shown, maybe the DVD unit is faulty?
All laptops will play CD/DVD from boot without drivers. The drivers are there to allow you to do specifics to the DVDs.
HP Pavilion... | Answered on Dec 16, 2019
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
To fix 0x80070057 errors you need to follow the steps given below:
Update Windows driver:
An obsolete driver can be one reason for causing this error problem.
Therefore to remove 0x80070057 errors message from your system you need to update your Windows driver.
For that you must
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html also
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Registry repair: Corruption to the registry can cause 0x80070057 errors to appear. Registry is the storehouse of files and program settings. Therefore frequent access to the registry key can cause corruption to it. Therefore you need to to repair the
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
registry. also http://download.cnet.com/ccleaner/
If the error problem still remains in your system then it is recommended to
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
It might be possible that due to virus or malware has infected your system that's causing 0x80070057 errors.
The anti spyware software will remove the viruses and make your system clean.
Hence increases the performance level of your system.
all of this is freeware
hope this helps
if there are any stubborn drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
HP Pavilion... | Answered on Jul 31, 2019
you can try going into your control panel and look for the speaker icon click in there and you should be able to set your sound settings.
HP Pavilion... | Answered on Jul 15, 2019
The 0xc0000185 error simply means that the computer can't communicate with the CD drive. It could be due to a faulty CD drive or media, a bad connection, faulty interface, bad memory, power supply etc. You will need to isolate the problem further, why couldn't you boot normally? check the BIOS settings again and try clearing the CMOS memory correctly as described in the manual (just removing the battery may not be good enough).
HP Pavilion... | Answered on Jul 02, 2019
I am assuming you are wanting install this on a HP machine, so all you should need to do, is go to the HP website if you use the machine you want to install it on, the web site should be able to detect, your make and model, and if any software is missing it will direct you to the page where you can download the software, and install it in the same way you install any other application in windows.
HP Pavilion... | Answered on Jun 12, 2019
which email service you use go to it
type in your ID name & in the same menu box
look for CAN'T LOGIN TO MY ACCOUNT
and follow the prompts
HP Pavilion... | Answered on Feb 12, 2019
old post, I do only 2018 posts)
first off why the huge contradiction even HP and ASUS mixed.
photo of laptop, and title, NOTEBOOK
and texting a Desktop, but must be a so i moved you....
p6126f PAVILION. it is. no monitor stated, at all. no errors show on monitor, like no signal?
the PC blue light means it thinks its one.
the fans must blow, both PSU and CPU or you have no 12vdc power.
the uSB ports have power, but that happens even with PC in standby mode, or even turned off, that is how I charge my cell phone PC off, using my USB ports,
what matters is:
1: monitor errors, seen
2: Fans.
3; you clicked shut down via what< windows, linux what?
if you CLICKED shut down and the fans don't go dead
that means your OS is corrupted. for sure.
top reasons are bad drivers, and vista can't shut down.
or worse. there is always that. (virus)
I'd DUMP vista, nobody on earth wants to help anyone with a dead vista , horrid VISTA, did you know MS in there great wisdom failed to add recovery mode to vista, yah sux, swap gas. that.
upgrade to w7 and end this silly mess called vista.
w7-64bit is best here, with full HP support seen here.
this is not spam, its the real HP, the place with no malware,etc.
https://support.hp.com/us-en/product/hp-pavilion-p6100-desktop-pc-series/3942799/model/3999655/product-info
HP Pavilion... | Answered on Dec 11, 2018
Take it back to the retailer. Unless it is more than a year old. The graphics chip or screen has failed.
HP Pavilion d4100y (PX181AV) PC Desktop Logo
Popular Tags
12 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
dvd lightscribe r rw drive not
  • Computers & Internet
