20 Most Recent KitchenAid Kitchen Aid KV25GOXOB - Professional 5 Plus Series 5 Quart Stand Mixer Questions & Answers
Motorhead wobbles
It will be to do with the hinge pin, the head lock or the head height adjustment. Make sure that the hing pin is held tight in place with the grub screw in the middle accessed only when the mixer & stand are upside down. Then make sure that the head height is correctly set with the adjustment accessed from the front when the head is raised. You can see the adjustment screw in the middle of the hinge when you have raised the head. In to lower the head and out to raise the head. The flat paddle needs to just stop tinging on the bowl when the motor is operating and the head is down.
11/2/2019 5:53:40 PM • KitchenAid... • Answered on Nov 02, 2019
KitchenAid Professional 5 Quart stand mixer grain mill won't grind?
From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears. https://www.google.com/search?q=olympus+s924+manual A Moulinex Coffee Mill might be a better solution for grinding wheat. ..
4/16/2023 11:16:47 PM • KitchenAid Food... • Answered on Apr 16, 2023
New Artisan Kitchenaid mixer KSM150 out of the box, head won't lock.
Don't forget if it is new it is under manufacturer warranty. Make the beater isn't too low and fouling, because the bowl is set too high? Try to lock with no beater.
3/25/2023 5:11:48 AM • KitchenAid Food... • Answered on Mar 25, 2023
3answers
Trying to adjust the beater to bowl clearance on my bowl lift KitchenAid K5SS. Mine has only pairs of screws, unlike manual diagram
Possibly one screw for up and one for down, working on a see-saw mechanism.
2/6/2023 9:52:44 PM • KitchenAid Food... • Answered on Feb 06, 2023
How to convert kitchenaid mixer from 220v to 110v
It's perfectly save to use a power converter from 220v to 110V. The 50Hz Frequenz will let the Motor spin 20% slower. So it'll last forever. I use a KSM90 from the US in Germany for more than 25 years. It runs great and the gears inside it look like new.
2/5/2023 12:30:16 PM • KitchenAid Food... • Answered on Feb 05, 2023
Kitchenaid Professional 6 Quart Mixer. The speed lever is stuck.
Question edited for clarity. Question moved to category. The speed lever is electronic. Videos and the part in the link. https://www.google.com/search?q=Kitchenaid+Professional+6+mixer+speed+lever+stuck ..
12/19/2022 12:42:07 AM • KitchenAid Food... • Answered on Dec 19, 2022
3answers
Kitchenaid mixer repair manual
google kv25g0xwh manual
7/30/2022 5:31:02 AM • KitchenAid Food... • Answered on Jul 30, 2022
2answers
How am I to disassemble my KitchenAid 7 speed hand mixer?
Try this video although '7 Speed' isn't an Alpha Numeric model number :>) https://www.google.com/search?q=disassemble+my+KitchenAid+7+speed+hand+mixer ..
7/30/2022 5:20:45 AM • KitchenAid Food... • Answered on Jul 30, 2022
Can i use it to make panko?
Panko are made with a special non-fermented bread that has no crust. You can however make good breadcrumbs with old hard bread and if you want it to be like Panko, pulse it and leave the crumbs coarse. I am a trade chef and use Panko a lot. Panko (???) is a type of flaky bread crumbs used in Japanese cuisine as a crunchy coating for fried foods, such as tonkatsu. Panko is made from bread baked by electrical current, which yields a bread without a crust, and then grinding the bread to create fine slivers of crumb.[1] It has a crisper, airier texture than most types of breading found in Western cuisine and maintains its texture baked or deep fried, resulting in a lighter coating.[2] Outside Japan, its use is becoming more popular in both Asian and non-Asian dishes. It is often used on seafood and is often available in Asian markets, speciality stores, and, increasingly, in many large supermarkets. Panko is produced worldwide, particularly in Asian countries, including Japan, Korea, Malaysia, Thailand, China, and Vietnam.
2/26/2022 5:54:01 PM • KitchenAid Food... • Answered on Feb 26, 2022
How do the governor and speed control plate work in a Hobart Kitchenaid K5-A stand mixer?
Before you swap it out, get a can of electrical contact cleaner and spray the track and contacts.
2/22/2022 3:20:17 PM • KitchenAid Food... • Answered on Feb 22, 2022
2answers
Kitchenaid KSM5 mixer - the power lever is hitting/missing to turn it on.
Sounds like your switch is going bad if it's an older machine that would be my guess and I usually guess right
11/26/2021 8:32:49 PM • KitchenAid Food... • Answered on Nov 26, 2021
110v KitchenAid artisan running twice the stir speed.
It's a 110 volt 1200 watt mixer and you are supplying it with 220 volts 500 watts of electricity through the inverter.https://www.walmart.com/ip/110V-Stand-Mixer-1200W-6-Speed-Tilt-Head-Electric-Food-Mixer-Dough-Hook-Mixing-Beater-Whisk-Splash-Guard-4-2QT-Stainless-Steel-Bowl-Red/353191351Now for the odd part, an 'inverter' takes a small number of volts usually 12 volts DC (direct current) and inverts it into 110 volts AC (alternating current) inverting the sine wave at 60 cycles per second..If you have a 220 volts supply and want to power an appliance that is 110 volts, you need a TRANSFORMER not an inverter. You are taking 220 volts AC and transforming it into 110 volts AC. That transformer needs to be able to supply more watts than your appliance. In your case 1,500 to 2,000 watts output. Something like this. My advice, buy a new mixer, sell the old one back home.https://www.amazon.co.uk/MSKJ-Converter-Transformer-220V-110V-Appliances/dp/B07CPNTNDD?th=1..
11/18/2021 3:58:53 PM • KitchenAid Food... • Answered on Nov 18, 2021
Hobart KitchenAid K5-A. Just replaced the grease and on reassembly, the planetary housing won't line up (vertically) with the pin hole.
Sounds like movement on the shaft. Grab the end of the shaft with grips and pull it towards you. Then put the gear on without pushing it back in. Here is a parts schematic, but lots of parts are obsolete. I could do with one of these myself for making bread! https://www.ereplacementparts.com/kitchenaid-k5a-mixer-parts-c-114958_114959_290214.html ..
10/4/2021 10:54:42 PM • KitchenAid Food... • Answered on Oct 04, 2021
How can I Fix my Kitchenaid 6qt 590Watts mixer. It wasnt used for maybe 9months made loud noises for a while i turned it off. Never came back on.
My first inclination, is the noise was the brushes burning out, If you over did it, you may have burned out the motor, then it "is" trash. "If" it is just the brushes, that can be fixed, take it to your local appliance repair guy to have it checked.
8/7/2021 6:03:00 PM • KitchenAid Food... • Answered on Aug 07, 2021
KitchenAid Mixer struggling to spin?
Check everything you have done for a mistake, the pin through the planetary, the pin through the fuse gear and the pin in the main shaft that drives the bevel gear. That's the gear that pinion gear on the fuse gear shaft mates with. After that you are left with a fuse gear fault. I am assuming that the motor is turning at normal speeds and not somehow binding up, no reason why it should as motor stays in one piece during gear changing procedure.
7/20/2021 3:08:23 PM • KitchenAid Food... • Answered on Jul 20, 2021
KitchenAid Kitchen Aid KV25GOXOB - Professional 5 Plus Series 5 Quart Stand Mixer Logo
1 questions posted
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
motorhead wobbles
  • Food Mixers
