20 Most Recent KitchenAid KP26M1XPM Professional 600 Series 6Qt Stand Mixer Questions & Answers
Mixer will not start
1/18/2018 8:42:11 PM • KitchenAid... • Answered on Jan 18, 2018
I need help with determining what likely parts need to be swapped out after an electrical short in my stand mixer
The motor for sure. The speed selector too.
9/15/2016 8:28:18 PM • KitchenAid... • Answered on Sep 15, 2016
One speed on slide switch will not go high or low
It's most likely a bad sensor. If a new sensor doesn't fix the problem, then the circuit board would have to be replaced as well.
11/20/2014 5:13:27 AM • KitchenAid... • Answered on Nov 20, 2014
When strart the mixer it go by 15 seconds and stop
you need to replace the speed control plate in the back of the mixer, there is a chance that it just need adjusting by way of the three silver screws on the plate but the part is cheap enough that it is worth replacing, you can find the part on ebay and instructions step by step on youtube.
4/18/2013 3:30:52 AM • KitchenAid... • Answered on Apr 18, 2013
I have a KP26MIXWH mixer that when I turn it on at it's lowest speed it immediately runs up to it's highest speed and then stops. None of the other settings will get the motor to turn althoug
On the professional 600 model there is a speed control board (Computer board) that is probably the culprit. Easy fix cost $30-$35.00 dollars for the part plus shipping. if you are under warranty then Kitchenaid will fix. If not you can do it quickly. Go to kitchenaid site look for support tab on right top side of window and click it, look for get user guides and manuals in the next window, click it, enter on the right side of the next page the model number and who you are (consumer), then you will be taken to another page that has the manuals listed on the left the upper manual is for user guide the lower manual is for parts list. Down load the parts guide / list so that you can find your particular speed board and it will show you how to disassemble and replace. It really is an easy fix. Not messy or complicated, just take your time and lay your parts out in a manner that will make YOU remember how they go back in. There are no other computer boards in the mixer so you will have no problem recognizing it. call Kitchenaid customer service and ask where the nearest service center is, if you live close by take your part number to the center and you can probably get it at the parts desk (fast parts, more expensive than internet, no shipping costs) Please let us know if this helps or if you need more help, that's why we're here.
9/20/2012 5:46:42 PM • KitchenAid... • Answered on Sep 20, 2012
KitchenAid Professional 5 Quart stand mixer grain mill won't grind?
From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears. https://www.google.com/search?q=olympus+s924+manual A Moulinex Coffee Mill might be a better solution for grinding wheat. ..
4/16/2023 11:16:47 PM • KitchenAid Food... • Answered on Apr 16, 2023
New Artisan Kitchenaid mixer KSM150 out of the box, head won't lock.
Don't forget if it is new it is under manufacturer warranty. Make the beater isn't too low and fouling, because the bowl is set too high? Try to lock with no beater.
3/25/2023 5:11:48 AM • KitchenAid Food... • Answered on Mar 25, 2023
3answers
Trying to adjust the beater to bowl clearance on my bowl lift KitchenAid K5SS. Mine has only pairs of screws, unlike manual diagram
Possibly one screw for up and one for down, working on a see-saw mechanism.
2/6/2023 9:52:44 PM • KitchenAid Food... • Answered on Feb 06, 2023
How to convert kitchenaid mixer from 220v to 110v
It's perfectly save to use a power converter from 220v to 110V. The 50Hz Frequenz will let the Motor spin 20% slower. So it'll last forever. I use a KSM90 from the US in Germany for more than 25 years. It runs great and the gears inside it look like new.
2/5/2023 12:30:16 PM • KitchenAid Food... • Answered on Feb 05, 2023
Kitchenaid Professional 6 Quart Mixer. The speed lever is stuck.
Question edited for clarity. Question moved to category. The speed lever is electronic. Videos and the part in the link. https://www.google.com/search?q=Kitchenaid+Professional+6+mixer+speed+lever+stuck ..
12/19/2022 12:42:07 AM • KitchenAid Food... • Answered on Dec 19, 2022
3answers
Kitchenaid mixer repair manual
google kv25g0xwh manual
7/30/2022 5:31:02 AM • KitchenAid Food... • Answered on Jul 30, 2022
2answers
How am I to disassemble my KitchenAid 7 speed hand mixer?
Try this video although '7 Speed' isn't an Alpha Numeric model number :>) https://www.google.com/search?q=disassemble+my+KitchenAid+7+speed+hand+mixer ..
7/30/2022 5:20:45 AM • KitchenAid Food... • Answered on Jul 30, 2022
Can i use it to make panko?
Panko are made with a special non-fermented bread that has no crust. You can however make good breadcrumbs with old hard bread and if you want it to be like Panko, pulse it and leave the crumbs coarse. I am a trade chef and use Panko a lot. Panko (???) is a type of flaky bread crumbs used in Japanese cuisine as a crunchy coating for fried foods, such as tonkatsu. Panko is made from bread baked by electrical current, which yields a bread without a crust, and then grinding the bread to create fine slivers of crumb.[1] It has a crisper, airier texture than most types of breading found in Western cuisine and maintains its texture baked or deep fried, resulting in a lighter coating.[2] Outside Japan, its use is becoming more popular in both Asian and non-Asian dishes. It is often used on seafood and is often available in Asian markets, speciality stores, and, increasingly, in many large supermarkets. Panko is produced worldwide, particularly in Asian countries, including Japan, Korea, Malaysia, Thailand, China, and Vietnam.
2/26/2022 5:54:01 PM • KitchenAid Food... • Answered on Feb 26, 2022
How do the governor and speed control plate work in a Hobart Kitchenaid K5-A stand mixer?
Before you swap it out, get a can of electrical contact cleaner and spray the track and contacts.
2/22/2022 3:20:17 PM • KitchenAid Food... • Answered on Feb 22, 2022
2answers
Kitchenaid KSM5 mixer - the power lever is hitting/missing to turn it on.
Sounds like your switch is going bad if it's an older machine that would be my guess and I usually guess right
11/26/2021 8:32:49 PM • KitchenAid Food... • Answered on Nov 26, 2021
KitchenAid KP26M1XPM Professional 600 Series 6Qt Stand Mixer Logo
Popular Tags
8 questions posted
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
one speed slide switch will not go high
  • Food Mixers
