20 Most Recent
Neff 24 in. S5409X0 Built-in Dishwasher Questions & Answers
How to fix neff dishwasher
Sounds like you have water in the base of the appliance caused by a leak, which in turn has activated the anti flooding device. OR the control module is faulty.
Remove appliance from housing and remove water from base, check for leaks.
OR
Replaced control module
We have a neff dishwasher and the pump is draining
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
Dishwasher will not drain
Hello there and welcome to fixya Please check the following carefully
Drain line/air gap
A
clog in the drain line or air gap (if there is one) is the usual reason
that a dishwasher won't drain. Often the problem is at the point where
the drain line attaches to the garbage disposer or household drain line.
If you remove this line, you can clear any debris from the hose or hose
connection. Be sure to reattach the hose before starting the dishwasher
again.
Pump
Your
dishwasher pump ejects the water. The pump is usually mounted directly
to the motor, then attached to the bottom of the dishwasher. You can
reach the pump from inside the dishwasher, but first you need to remove
the lower rack, the spray arm, and the spray arm support.
Look
for an impeller--a round plastic fan blade-type of device that spins
around. This is the wash impeller, which forces the water through the
spray arm. Beneath the wash impeller is the drain impeller, which is
similar in size and shape to the wash impeller. The drain impeller
pushes the water toward the drain port. These components make up the
pump. If any of the pump components are defective, you need to replace
them.
Drain valve and/or solenoid
Many
dishwashers use a drain valve with an electric solenoid. When
electricity flows to the solenoid, the valve opens and diverts the water
to the drain. Sometimes the solenoid, or the diverting lever, sticks
and prevents the dishwasher from draining or filling properly. Try to
free up the solenoid to lubricate the lever. Otherwise, you may have to
replace the solenoid or pump assembly. With these systems, the motor
always rotates in one direction. When it's energized, the drain valve
diverts the water.
Other
dishwashers simply reverse the direction of the motor to drain the
dishwasher. These units don't have a drain valve. Instead, there's a
drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If
the motor isn't turning or working, the unit won't drain. First check
to be sure you have power to the dishwasher. If not, see the section "It
doesn't work at all." If the motor hums but doesn't turn, it may need
to be replaced.
Some
dishwashers are susceptible to getting stuck if you don't run them
regularly. If you haven't run the dishwasher for more than a week, you
may need to manually spin the motor to free it up. If the motor is
defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part
of what the timer does is control the motor and drain valve. If the
timer doesn't work properly, the water may not drain and you need to
replace the timer. This problem is uncommon.
Tablet wont dissolve
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
After a run, the water
Could be your filter in base of dishwasher needs to be cleaned out.
Remove it and make sure the hole where the filter came out of is cleaned out with cloth before putting the cleaned filter back in.
How do I reset my GE GSD5630 Dishwasher?
To do a hard reset on this washer you need to unplug the unit from the wall outlet behind the unit or simply turn off the circuit breaker. Leave it off for approximately 3 to 5 minutes and the memory will reset.
I had to do this to my GE Triton dish washer a few times when for some unknown reason it would not start a new wash cycle no matter what buttons I pushed.
Todd
I have a neff S5049X, pump keeps runing on even
Sounds like the anti-flood device has kicked in this would suggest that there is either a leak under the machine or if you may have used too much rinse aid and it has frothed up and leaked under the door.
The screw in the middle is to lower the middle rear leg turn it towards the down or minus sign normally anti-clockwise.
Hope this helped.
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
No water
Check first the filters on the inlet water line.
Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
