20 Most Recent Neff 24 in. S5453X1 Built-in Dishwasher Questions & Answers
Controller could be defective
Neff 24 in.... | Answered on Dec 16, 2017
There most likely is a problem with heating element or a wire shorting
Neff 24 in.... | Answered on Nov 07, 2017
Most dishwashers kick on a valve to fill with water.
There's a float in there somewhere that triggers the shut off to the filling water.
Once water reaches this cut off level the pump should be throwing water thru the wash arms.
If base isn't filling to capacity...Id look to the drain valve.
If it fills to capacity and stops...the pump may be out or something is obstructing it.
Hope this helps...
Neff 24 in.... | Answered on Oct 18, 2016
Check the small round filter mesh, make sure its clean and that its not clogged. Use a degreaser on your machine then put it throught a hot wash to rinse it through.
Remove the bottom and top spray bar and inspect the spray holes and make sure they are completly un obstructed. Replace the spray bar and check that they spin freely. If they are not spinning well remove them again and check the mating surfaces for contamination and wear. if they are worn both the spray bay and their respective receptacles will need replacing.
Neff 24 in.... | Answered on Oct 03, 2012
if the door is not closing do you mean will not stay closed this may be because of the locking hasp or the handle/lock located on the door on the top of the unit if the door is not moving up and down then this would because of the lower pulleys inspect your machine further and message me back with your finds Thanks again Rick
Neff 24 in.... | Answered on Sep 30, 2012
Neff 24 in. S5453X1 Built-in Dishwasher Logo
76 questions posted
Top Neff Dishwashers Experts
Ekse
Marvin
Marvin
vince
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Neff Dishwashers
  • Neff Dishwashers
Most Popular Question
machine but water stopped coming
  • Dishwashers
