20 Most Recent Neff 24 in. S4457 Built-in Dishwasher Questions & Answers
My dishwasher works perfectly but makes a loud humming noise through whole cycle
Remove the filters and look into the sump (if the back of the sump is 12 o clock) look at approx 2 oclock and you will see a hole that draws the water in to the circulation pump (sometimes covered with an extra piece of plastic that can be clipped off) put you finger in there and see if you can feel any obstructions, if so remove. (you may find that cling wrap or a dishwasher tab packet has got in there and is stopping the motor running to full capacity and/or making it noisy). Maybe take the spray arms off and check the holes in them are not blocked, as this will also cause strange noises.
3/22/2013 1:37:16 AM • Neff 24 in.... • Answered on Mar 22, 2013
0answers
0answers
Where can i buy a Bitron type 902?
Hi try the following company; I have found them very efficient and helpful.
eSpares. com[[email protected]]
12/5/2010 2:45:56 PM • Neff 24 in.... • Answered on Dec 05, 2010
The tablet is not disolving and leaves a white
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
10/27/2010 3:44:33 AM • Neff 24 in.... • Answered on Oct 27, 2010
The dishwater tablet has not been used by the end
Hi seems wash cycle not happening
is temp on cold warm hot
make sure wash cycle is selected 60c
ok
9/16/2010 10:27:54 AM • Neff 24 in.... • Answered on Sep 16, 2010
My Neff dishwasher is showing E15 code plus showing a light on the tap symbol. I have had to switch it off at the plug as it keeps making a noise when switched off?
Could be an over fill issue causing water to leak into the base. What you need to do is pull the dishwasher out and lay it on its back and this will allow the water to drain out from the base.
3/21/2024 9:29:33 AM • Neff Dishwashers • Answered on Mar 21, 2024
2answers
I have a neff dishwasher showing an error 25 code
They discuss code 25 on this site: https://www.youtube.com/watch?v=zDHXtu-FaQg Also, here is a good video on You Tube: https://www.youtube.com/watch?v=-fQZ8p2yEJY
12/12/2023 10:14:53 PM • Neff Dishwashers • Answered on Dec 12, 2023
What do I need to do if I put rinse aid in the salt compartment, is that a problem?
Shouldn't be a problem. Top up with salt as soon as you can. That will avoid streaky glassware.
8/27/2023 10:27:42 AM • Neff Dishwashers • Answered on Aug 27, 2023
My NEFF integrated dishwasher will not fill
It sounds like there may be an issue with the control board or programming of your NEFF dishwasher. The fact that the impeller runs and the rotor arms spin when water is manually added to the sump, but the controller does not call for water when the sump is empty suggests that there is a problem with the communication between the control board and the water inlet valve. The round white device you mentioned that is located in the water inlet before the water inlet valve is likely a flow meter. It is used to measure the amount of water flowing into the dishwasher and send a signal to the control board to indicate when the appropriate amount of water has been reached. This device could be malfunctioning and preventing the control board from requesting water. It's also possible that the problem is with the level float and plunger that operate the micro switch you mentioned. If the float and plunger are not working correctly, the control board may be receiving incorrect information about the water level in the sump and preventing the dishwasher from filling with water. It is best to check the user manual for the dishwasher, it will have the troubleshooting section, you can try the solution mentioned there. If the problem persists, it is best to contact NEFF customer service or an appliance repair professional for further assistance.
1/23/2023 12:22:14 PM • Neff Dishwashers • Answered on Jan 23, 2023
Neff Integrated Dishwasher. The pump on my dishwasher won't stop running!
That is the classic behaviour of a flood sensor being wet. You said 'anti flood float'. I know them as a small sensor in a tray under the machine and above the floor in a plastic pan. If it is that where your float is, then you need a service call to diagnose. It is likely to be a circuit board issue and they are expensive so need proper eyes-on trained diagnosis.
3/26/2022 8:37:55 PM • Neff Dishwashers • Answered on Mar 26, 2022
Type S5444. Why doesn't it fill?
follow the water
5/24/2021 10:57:45 AM • Neff Dishwashers • Answered on May 24, 2021
2answers
Neff dishwasher beeps once when I start it and close the door but doesn't start
8 reasons : https://www.appliance-insurance.co.uk/appliance-insurance-articles/reasons-dishwasher-beeping/ Dishwashers equipped with an electronic control, which may display blinking lights or have beeping sounds. ... A beeping sound every 30 seconds: Indicates the dishwasher door was unlatched during the cycle. Close the dishwasher door to resume the cycle. https://products.geappliances.com/appliance/gea-support-search-content?contentId=17380
5/13/2020 9:23:01 PM • Neff Dishwashers • Answered on May 13, 2020
My Neff dfn60 dishwasher has no power
I suggest looking under the sink. Some dishwashers simply are plugged into an outlet under the sink.
It very well could have came unplugged.
If that isn’t what it is most likely a breaker has tripped in your breaker box. Try to identify the tripped breaker. Switch to the left and then to the right. Check and see if you now have power.
If neither of these, I would suggest calling a appliance repair technician.
I hope this information helps. Have a blessed day!
11/15/2019 4:27:31 PM • Neff Dishwashers • Answered on Nov 15, 2019
NEFF s51e40x1gb/29 dishwasher button 7 flashing
Taken From the Manual (https://media3.neff-international.com/Documents/9000816278_I.pdf) If the appliance stops during dishwashing or does not start for no obvious reason, first run the Abort programme function (Reset). Terminating the programme (Reset) 1. Open the door. 2. Press START button 9 for approx. 3 sec. until all displays go out. 3. Close the door. The remaining programme sequence for draining the residual water takes approx. 1 minute.
8/19/2019 10:42:14 PM • Neff Dishwashers • Answered on Aug 19, 2019
Neff 24 in. S4457 Built-in Dishwasher Logo
Popular Tags
17 questions posted
Top Neff Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Tracy
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Neff Dishwashers
  • Neff Dishwashers
Most Popular Question
  • Dishwashers
