20 Most Recent
KitchenAid Kitchen Aid KL26M8XOB - Pro Line Series Stand Mixer, 6 qt, Pouring Shi Questions & Answers
After cleaning my kitchen aid mixer it won't turn on
You must have water in the controls, use a blower dryer and dry it all out or just let it set for a few days and see if it works again, if not you must have done something wrong assembling it, what that might be is really hard to say.
The blue power on light does not light up when pressed on my Kitchenaid KES100 espresso machine although the high pressure pump runs when the button is pressed. Neither boiler heats up.
You will need to test for where the power stops & check the fuses on each boiler for continuity. If you find any blown then replace the thermostat on that boiler along with the fuses. The thermostats are different rating for each boiler, don't mix them up. It's highly unusual for both boilers to fail at the same time. Occasionally one of the boiler elements can fail, there are 2 elements on each boiler, check them for continuity. If you have any boiler leaks then replace all the seals on that boiler, the steam one is the one most likely to leak. Buy your own seals using the old ones as samples from someone specialising in O ring supply. There are 5 seals on each boiler. Do not purchase rubber or silicone seals, only use Viton seals, they are high temperature.
