20 Most Recent Neff B1432 Single circotherm plus Electric Oven Questions & Answers
In general it is a pain in the rear to do this if you are not familiar with this little trick.
Neff B1432... | Answered on Dec 04, 2017
Yes it wil continue to work on manual basis
Neff B1432... | Answered on Oct 20, 2017
Re-confirm your model number, I could not come up with results thru my source.
Neff B1432... | Answered on Jul 20, 2015
I have a Neff B1451 oven and have removed the thermostat knob just by pulling and wiggling it. Thats all you do. If then you want to rpelace the thermostat, there are two screws holding the unit onto the oven which are accessed by taking the silver metal shrouds off first.
Neff B1432... | Answered on Oct 16, 2011
I believe this is the oven door seal. You can purchase this online from Ransomespares.co.uk product code RS46105 cost £29.25. Easy to fit, each rounded corner has little metal hooks which fit into the pre-drilled hole on the oven itself, simply unhook the old one and replace with the new, simple.
Neff B1432... | Answered on Sep 12, 2011
either the new element is faulty, or you are not getting a supply to it, you need to check with a meter to see if you are getting voltage to the element.
Neff B1432... | Answered on Aug 08, 2011
Could be a faulty thermostat, but I would check that element is getting hot before commiting to replace the thermostat.
Run it for a few minutes and feel to see if you can feel hot air blowing from fan at rear of oven. If no heat present, thei it will be the elemnt that is faulty.
Neff B1432... | Answered on Jan 09, 2011
I think you will find the fan element has failed, this will explain why it works o/k on coventional oven, as another element is used.
The fan element is located at rear of oven compartment behind a removeable cover.
Neff B1432... | Answered on Dec 28, 2010
On the link below if you click and open on first manual on page 65 tells you how to remove and reinstall your oven door. All the manuals are the same you just need to click on one and get to the oven do removal.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Neff B1432... | Answered on Aug 17, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Neff B1432... | Answered on Aug 15, 2010
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Neff B1432... | Answered on Apr 28, 2010
Neff B1432 Single circotherm plus Electric Oven Logo
40 questions posted
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
Domenico Grillo
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
neff b1432 working
  • Ovens
