The oven element is faulty, and needs replacing.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Use linkhttp://www.neffcustomerservice.co.uk/click on instruction manual download (bottom left of page) this will open new window, enter U1452 in search box... click on first result and go to page 36 of downloaded PDF this will give you the instructions.All the best, hope this helps
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Depends on whether you purchase a genuine element or a copy one.
You could get a copy one for under £10.00, or pay as much as £30.00 for a genuine element.
I;m afraid the only real solution here is to replace the offending motor, as this is an indication that the fan bearings are worn and that it will eventually fail altogether.
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Neff fan motorin the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter. To gain access to the NEFFelement you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the elementyou willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the elementis open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine. 2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motoris working you willsee the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven thenyou need To replace the oven fan motoris a little moreexpensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat 4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timerinto AUTO mode,simply put oven back to MANUAL mode and all should be working again.
they should last 12 months minimum there could be a problem with your fan motor here is a standard fan oven check list.
You-Tube video "6QGurNvbI0Q" placeholder (do not delete)
TUTORIALS1, If the fan motorin the back of the oven is going round and
electric meter. To gain access to the element you will
from the rear of the machine. 2, If your fan oven is getting warm but takes a very long time to
cook or is burning the food more on one side than the other, then you need to
and burning everything then you will need to replace youroven thermostat 4, A quite common and easily overlooked answer is if youroven is not working at all ie: no heat
