20 Most Recent Sony VAIO K45 Notebook Questions & Answers
No power problem
These cables get screwed up easy.. (contacts fold back or get pulled out of alignment).. they can be bought at sony online usually..
11/30/2018 10:52:04 AM • Sony VAIO K45... • Answered on Nov 30, 2018
My Sony PCG K45 laptop
That means the laptop is not recognizing that it has a hard drive installed. The settings may have gotten messed up in BIOS regarding boot order as well. Given that model initially shipped with XP, I would say the hard drive is old enough that it could have failed.
11/11/2017 11:25:54 AM • Sony VAIO K45... • Answered on Nov 11, 2017
Repair manual pcg
The best way to get free service manual of your machine is to visit and find it in your manufacturer`s website.
10/30/2013 1:15:35 PM • Sony VAIO K45... • Answered on Oct 30, 2013
3answers
DIAGRAM FOR SONY VAIO PCG-k45 (service Manual) free download
Try this website. Full of detailed information with downloads of service manuals.
http://www.laptoprepair101.com/laptop/category/laptop-service-manual/
8/16/2013 6:49:47 PM • Sony VAIO K45... • Answered on Aug 16, 2013
2answers
My picture is not the full size of the screen
if you're using Vista, you can right click on your desktop and choose personalize then choose Desktop Background. at the bottom part of the Desktop Background page you will see options on how you want the picture to be seen. choose the first one, which is Fit to screen, if you want the picture to be seen in the whole screen.
6/16/2013 2:07:43 PM • Sony VAIO K45... • Answered on Jun 16, 2013
2answers
Can't get to Norton to turn it off.
you can..and go to pack.google.com to get a free version of Norton Net Security
1/3/2013 8:45:16 PM • Sony VAIO K45... • Answered on Jan 03, 2013
I bought a new screen for my Sony Vaio pcg-71912L, but when i changed and i tried to turn on, the screen never turn on, i put back my old screen and it doesnt work either? somebody can help pls
The only thing left is the inverter board located just below the screen and is a common issue with a black screen, the inverter board drives the backlight behind the display.
6/22/2012 1:06:18 AM • Sony VAIO K45... • Answered on Jun 22, 2012
I can't boot from the Internal, or via an
hello, have you tried changing device boot orderfrom BIOS?
you should change device boot order or press the appropriate button (commonly F10) during POST (when laptop starts to initialy work, it writes which button the first 5seconds that it starts to work) and then you will see a box that shows all the availiable devices to try to boot from. All computers and laptops can boot from any internal or usb if these devices work properly and have a proper image to boot from.
9/19/2011 10:44:56 AM • Sony VAIO K45... • Answered on Sep 19, 2011
VIAO PCG-K45 While cleaning my battery
What may have happened is the spray entered the laptop as you suspect and shorted some components. More likely is the LCD toggled to the external monitor. There is a three state toggle for most laptops the toggle is done by holding the Fn key and taping another key such as F5. It may be different with your laptop. The beginning state is LCD only, External monitor only and then both. I try to keep laptop in the both state to reduce confusion and it doesn't require any more power.
Another possibility is shorting of the LCD cable. This would could cause no display video, but would more likely show no video at all.
You should always allow the laptop to completely dry, usually over night, before powering it back on after cleaning of this sort.
4/7/2011 4:51:38 PM • Sony VAIO K45... • Answered on Apr 07, 2011
Is there a quieter fan for the sony pcg-k45?
If your fan is very loud, and works all the time, then probably you'll need to clean up your laptop from the inside. On average it only takes 3 months for any laptop to gather enough dirt so the CPU heatsing gets totally clogged and this causes the fan to work all the time, and in extreme cases your laptop even turns off so it protects the CPU from the excess heat.
Here's a very good overheating laptop cleanup tutorial with some best practices that any laptop owner should know.
If this was informative and helpful please vote with a Thumb Up. Thank you.
1/30/2011 11:25:52 PM • Sony VAIO K45... • Answered on Jan 30, 2011
2answers
Well I have a Vaio
For that you need to reset bios to defaults . When you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios. then go to exit menu and reset all settings to defaults. Then save settings and exit. Also disable SATA and make sure harddrive is recognized in bios., If still same then you need to reconnect RAM .memory. It is on back side of laptop open it's cover and reconnect it into it's position. Let me know if you need further assistance. Thanks for using FixYa.
1/22/2011 6:01:03 PM • Sony VAIO K45... • Answered on Jan 22, 2011
2answers
How do I remove the dvd-rom drive from my Vaio
Check your support page, it has just what you need.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCGK45
12/22/2010 12:02:19 PM • Sony VAIO K45... • Answered on Dec 22, 2010
I have windows XP on
It is problem with the boot sector. There is a bad sector in the MBR. Whatever you do will not be a solution to remedy this problem. First of all you need to take a test of the primary hard drive. If it passes the test, backup all your data using a linux LIVE CD and then format the whole drive (all partitions) to ntfs using a Vista installer dvd. Re-install XP into the first partition of the drive. This will fix the problem parmanently.
Feel free to contact for any questions further. I am following up.
Have a nice day,
Regards.
12/13/2010 5:43:29 PM • Sony VAIO K45... • Answered on Dec 13, 2010
My Sony PCG K45
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
10/10/2010 6:32:03 PM • Sony VAIO K45... • Answered on Oct 10, 2010
How to adjust the brightness on my sony vaio
To adjust the brightness control, press Fn + F5 and release, plus the RIGHT ARROW or LEFT ARROW keys to increase or decrease the value.
On most notebook computers you can use the Fn+F5 keys to lower the screen brightness level, and the Fn+F6 keys to raise the screen brightness level.
6/24/2010 6:57:06 AM • Sony VAIO K45... • Answered on Jun 24, 2010
Cd rom wont recognize installation cd
Hi. You could try updating the driver for your Optical Drive and Deleting the Upper and lower filters by accessing the registry tool. follow this:
1. go to start search or RUN if you're using XP then type in there regedit then press enter
2. go to this folder HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. Look for Upper and Lower Filter files then delete them by doing a right click then delete. sometimes you could only find one of them but its fine, after deleting those files you should restart your computer
if this doesnt work, you should consider replacing the Optical Drive Already because maybe this already a hardware issue. or if it a hardware issue you could try cleaning the optical lens with cotton buds.
Hope this helps
6/2/2010 6:58:40 PM • Sony VAIO K45... • Answered on Jun 02, 2010
Operating system not found, computer just went
If u have warranty, contact sony.
Or else replace the HDD.
5/31/2010 5:06:37 PM • Sony VAIO K45... • Answered on May 31, 2010
2answers
Fan is running hot
That seems to be typical of that model. Oftentimes, it's the battery, microprocessor(s), or a combination of both. There are devices to cool the computer off, or you can use a small fan, that helps. Make sure it's not dirty inside (consult your manual on cleaning, or tech threads on this site). I wouldn't be alarmed, it seems to be typical with this model. Read the second review: http://www99.epinions.com/reviews/Sony_VAIO_PCG_K45_P4_538_3_2GHz_1MB_L2_533MHz_FSB_512MB_80GB_DVD_CDRW_56K_NIC_802_11bg_15_4_WXGA_XB_XP_PC_Notebook Good luck.
5/3/2010 9:57:46 AM • Sony VAIO K45... • Answered on May 03, 2010
Sony VAIO K45 Notebook Logo
Popular Tags
69 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
no power problem
  • Computers & Internet
