20 Most Recent
Sony VAIO VGN-A790 Notebook Questions & Answers
Hello, I cleaned out my
The first thing that I would try to do is to reseat your ram modules. Remove both ram modules, blow out the ports in case of dust, and then put them back in again securely. If this doesn't correct the problem, try it again. If the problem still persists, then you need to disassemble the laptop and reassemble it, checking for loose connections. There's also the possibility that an improperly placed screw is shorting out the motherboard because it's too long for the hole and is touching something, or that the heatsink isn't secure on the CPU.
9/22/2011 11:03:23 PM •
Sony VAIO...
Answered
on Sep 22, 2011
Battery will not show or charge even with new
With my laptop, I held the power button (still with everything removed) for 30 sec to decharge the capacitors. Finally, put the battery back in and plugged in the adaptor and everything worked
1/11/2011 5:46:14 PM •
Sony VAIO...
Answered
on Jan 11, 2011
My Vaio VGN-A790 runs really
No, the speed is normal, since the data speed (2GHz) is equal to the effective clock (688MHz) multiplied by the data rate (4).
The video problems are caused by the heat - memory corruption. Check the cooler and the fan of the processor for dust (clean the inside fully) and make sure in Task Manager that no process is eating power unnecessary, slowing the pc down.
8/24/2010 6:43:01 AM •
Sony VAIO...
Answered
on Aug 24, 2010
WHERE IS THE HARD DRIVE LOCATED
on bothem of notebook it are lockt with 4 srews open it and you can take out hd it are also with 2 srews blockt on mainboard
10/26/2009 11:08:12 AM •
Sony VAIO...
Answered
on Oct 26, 2009
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
