20 Most Recent Sony VAIO PCG-K23 Notebook Questions & Answers
Please refer to the article referred to below for a detailed diagnosis procedure of this issue:
https://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
Sony VAIO... | Answered on Nov 30, 2018
This can be usually done by a Windows Password Tool. However, if you have already activated the Administrator on the PC (Any Brand) with Windows 7. You can try the following steps.
Generally, the logon does not have the administration account listed. So one may want to go restart the machine to the Command Prompt to enable the Command Prompt.
Restart the Machine --> Tap F8 (Advanced boot options) --> Go Save Mode With Command Prompt --> Command Prompt Window appears. Type :
1: net user Administrator /active: yes
2: shutdown -r
This would restart the machine and the Windows Logon will have the Administration account. You can login to the Administration Account and then change the password on the other account.
Also, If you do not have the the admin account activated, then you may want to get windows key from http://www.lostwindowspassword.com/windows-password-recovery.htm
(This is a paid software).
You may get several free software's online as well.
Thanks,
Rahul a
Sony VAIO... | Answered on Jul 16, 2014
Any updates, if available, will be found on Sony's web site.
Sony VAIO... | Answered on Jan 24, 2014
go to bios menu and boot option boot external drive enable and change the boot order that's all
Sony VAIO... | Answered on Dec 05, 2013
There is not one. The password set on the bios is set by the owner of the laptop at ramdom.
Sony VAIO... | Answered on Nov 14, 2013
Try booting up into Windows Safe Mode (F8 during bootup or watch for an option for Boot Menu) and see if you're having the same issue.
Sony VAIO... | Answered on Oct 20, 2013
Try connecting the laptop to an external monitor if it works well. Be a problem in the laptop screen
Sony VAIO... | Answered on May 18, 2013
Which is what?
No display on internal monitor of laptop?
Squiggly lines or pink screen, or vertical or horizontal lines?
What is the problem?
Also is it a Sony VAIO PCG-K23 Notebook PC?
Post back in a Comment.
Regards,
joecoolvette
Sony VAIO... | Answered on Apr 30, 2013
Try downloading the Flash player from this WEB site.
http://get.adobe.com/flashplayer/
Sony VAIO... | Answered on Jan 21, 2013
can u see any dark image on lcd?
Sony VAIO... | Answered on Oct 07, 2012
What about Taking out the RAM and Removing your Backup Battery of the Laptop some time and putting it Back. This could do some Tricks.
Sony VAIO... | Answered on Aug 18, 2012
How much RAM do you have? Upgrading your RAM is a good way to improve system performance.
Sony VAIO... | Answered on Jun 26, 2012
Sub out the ram one at a time to see if that will fix the problem.
Sony VAIO... | Answered on May 23, 2012
cmos battery maybe bad?
Sony VAIO... | Answered on Mar 24, 2012
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sony VAIO... | Answered on Sep 14, 2011
    If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- https://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
    Sony VAIO... | Answered on Sep 01, 2011
    hi gyanurlabari....
    Go to the following webpage and download the Sony pcg-k23 drivers you need...
    Please take time to rate me
    http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGK23
    Sony VAIO... | Answered on Aug 29, 2011
    Sony VAIO PCG-K23 Notebook Logo
    193 questions posted
    Top Sony Computers & Internet Experts
    Ekse
    Alun Cox
    Thomas F. Schneider
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    VAIO Sony
    • VAIO Sony
    Most Popular Question
    sony vaio pcg 61911w driver
    • Computers & Internet
