20 Most Recent
Sony VAIO PCV-RS312V PC Desktop Questions & Answers
Questionable UPDATE install on PC
Not sure what the update could be, but to very its not a virus, try this FREE online tool. It is EXTREMELY good and removes viruses and malware that even Norton cannot. Remember to do a full system scan. May take a while, but is well worth it:
http://housecall65.trendmicro.com/Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.Thank you for using FIXYA!
Cheers!
IrishDruid
11/30/2018 11:30:00 AM •
Sony VAIO...
Answered
on Nov 30, 2018
I have a Vaio RS312V series that I haven't
This happened to me before but can no longer
change the admin password, so I have no
choice but to create a different user and
delete the old one. Here's how I did it:
1. Restart you computer
2. Press f5 before the windows logo appear
3. Select safe mode
4. Click start menu
5. Click control panel
6. Go to User accounts
7. You can. Ow delete that account and
create a new one
Hope this helps
10/18/2011 12:54:55 AM •
Sony VAIO...
Answered
on Oct 18, 2011
I have a sony vaio pcv-rs312v and i dont know how
could you explain better, because signal to monitor is via VGA cable.. VGA cable is attached to VGA port on back of CPU.. so hard disk? I will assist you better if you give more info.
Thanks for using fixya
9/16/2011 7:45:23 PM •
Sony VAIO...
Answered
on Sep 16, 2011
Sony vaio desktop recovery desk
You will have to get the "full recovery" install discs. The recover disc only restores the system if the hard drive is te original factory installed and has not been formatted.
-AAT
2/21/2011 5:48:00 PM •
Sony VAIO...
Answered
on Feb 21, 2011
I would lke to buy a larger monitor to watch
it depends on the connections you have coming out of your video card. Most large monitors come with both a DVI and VGA port, so you should be able to attach them to any computer.
3/27/2010 11:03:02 PM •
Sony VAIO...
Answered
on Mar 27, 2010
Disk boot failure, but i can't find my disk?
There aren't alot of solutions for these kind of problems, but it could be caused by a disk failure, due to use, age, failure in general, a problem with your motherboard perhaps, but whatso ever, it might be the best and safest to contact your local tecnician and have him check your pc for whatever failure occurs inside...
Hope this is useful, and greetings,
Olivier.
10/20/2009 5:17:43 PM •
Sony VAIO...
Answered
on Oct 20, 2009
It doesn't boot up
Shoot it... Or give a little more information... ^.^.
USUALLY, this is power supply related. If a PS is not working, or not working correctly, your machine will fail to start. If you hear fans and see yellow lights, but no green lights, that usually means the Power supply's CPU-power is not working within acceptable limits. If there are no lights and fans whatsoever, that usually means the ps is toast. But, just to be sure, make certain that the little red switch on the back is set to 115 instead of 230.
If you see a start-up screen (something that says SONY or VIAO when you turn it on) that means that you could have a faulty hard drive, or faulty memory. Your best option is call Sony or let a pc tech give it a look-see. Without more information, I can only make general suggestions.
If you DO decide to shoot it, make sure you do it ONLY during computer-hunting season, and make sure you have a license to hunt computers. ^.^
10/1/2009 10:44:54 PM •
Sony VAIO...
Answered
on Oct 01, 2009
Location of the hard drive
Turn the desktop round so the back of it is facing you.
Remove the screws that are on the bottom left and right, and in the top middle and remove the outer casing by sliding the case towards you.
Once the outer cover is removed face the case so you can see the motherboard.
The hard drive is located behind the front panel of the case underneath the CD/DVD drives.
It should be laid on its side with cables coming from it.
As far as i know the hard drive bay will just slide out but there may be holding screws.
Regards.
9/18/2009 6:45:18 AM •
Sony VAIO...
Answered
on Sep 18, 2009
VGC-VA1 battery repacement
There will be a battery on the motherboard. It will look like a watch battery about the size of a quarter. It should pop out easy.
Is your computer not even loading the manufacturer's screen?
1/28/2008 3:22:55 PM •
Sony VAIO...
Answered
on Jan 28, 2008
Thanks but I need help just getting online
It could be a difference configuration of the ethernet adapters on each machine.
Try this from each machine when connected to the cable.
(assumes Windows XP)
Click Start then All Programs then Accessories then Command Prompt A new window will open -- in that window type the following
ipconfig /all
If this works copy the following for each adapter (there may be more than one per machine)
Adapter
IP Address
Subnet Mask
Default Gateway
DNS Address(es) may be more than one
Put the answers in a comment to this problem and I will attempt to provide additional steps to resolve the issue.
one possibility --
If you loaded your DNS addresses into the laptop's adapter configuration and not into the desktop's laptop configuration that could be the issue.
There could be other issues the ipconfig answers should narrow down the problem so a specific solution can be given.
12/24/2007 12:12:58 AM •
Sony VAIO...
Answered
on Dec 24, 2007
Sony Vaio pcv-rs 312v
check whether your SMPS fan is running the back side of the cabinetand also the cpu fan if you can open the system case. if the both fan is running fine then rmove the CMOS battery and start the computer after 2 or 3 sec the cpu fan will stop that means BIOS is cleared reinsert the battery and boot the system go to BIOS and go to load default setting and enter(press DEL or f2 to enter BIOS) after that press f8 and go to safe mode (not work with win98)it will take some time,after getting in to the OS scan your computer for virus with best and latest updated ANTI VIRUS. let me know whether it is working ot not. if not working kindly let me know what the exact problem is write all the process you follow to start your PC reply me soon
11/14/2007 7:28:33 PM •
Sony VAIO...
Answered
on Nov 14, 2007
