Replacement of the
lamp should be carried out by a qualified appliance repair service.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
But here is a basic method if you are
mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its
position is adjacent to the vent holes that it shines through.
If
you feel confident, disconnect it from the mains power, remove
anything in the cavity.
Remove the microwave cover. Purchasing a
new replacement lamp will be useful as it will give you an idea of
what it looks like. Locate the dead lamp remove the lamp and fit the
new one. Replace the covers. Plug it back in and try the lamp by
opening the door.
Hope this helps.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
47 questions posted
47 Questions
36 Questions
35 Questions
35 Questions
29 Questions
