20 Most Recent Sharp Wizard OZ-590A Questions & Answers
0answers
0answers
0answers
I have a sharp wizard oz-590a with pc Sync. I
For some reason I have a CD that is labeled "Sharp Software CD-ROM OZ-590/ZQ-590". Could this be what you are looking for?
PS - I never owned one so I dont know why I have it.
3/20/2011 6:27:13 PM • Sharp Wizard... • Answered on Mar 20, 2011
How do you use the translate on oz-590A?
Word Translator
English-Spanish bi-directional word translator function is available
for download. Refer to "Downloading database" on page 32 for
details.
1. In the Main menu, tap
]to enter the Word Translator Mode.
2. English
Spanish translation is set by default. To change the
translation direction, tap the division arrow, or use
m
and/or
k .
3. Enter the desired source word and press
x. The matching
English or Spanish word will then be displayed.
• When the icon "
j" or "
l" is activated, more letters exist. To view
the remaining letters of long words that cannot be accommodated
on the screen, use
j or l to scroll.
• If there is no matching word, "NOT FOUND!" is displayed. The
word next in alphabetical order will then be displayed.
• Press
to scroll through the word list, or enter a new
word using the keyboard, and press
xfor another search.
Notes:
• If you choose not to download the Dictionary Database for the
English/Spanish Translator, then the extra memory space will be
utilized by other applications.
In such case however, the Word Translator function will be disabled;
tapping the
]icon will display a message "NO DATA!".
To learn how to download the Dictionary Database, refer to the
section "Downloading database" on page 32.
• The downloaded database for this Word Translator is utilized also by
the Spell checker; do not delete the database if you intend to use the
Spell checker function.
5-Language Phrase Mode
5-Language Phrase Mode is available for download. Refer to
"Downloading database" on page 32 for details.
Select an English key phrase to find equivalent expressions in four
different languages - German, French, Italian, and Spanish.
A phrase can be browsed under a traveling situation, or can be
selected from a list of words.
To search phrases in a certain situation
1. In the Main menu, tap Phrases to
enter the Phrase Mode.
2. Select the desired target language.
3. Select the desired scene to
browse the relevant phrases. For
example, select "3. Airport".
4. Tap the desired phrase to select.
Tapping the phrase one more time
to display the entire phrase.
5. Press
x to display the equivalent phrase in the target
language.
The Database menu of the Desktop Utilities allows you to download
database for the Word Translator / Spell Checker, and 5-Language
Phrase Mode from the CD-ROM.
1. Insert the PC software CD-ROM.
2. Click "Download" in the Database of the Desktop Utilities.
3. Select a file you wish to download, then click "Open".
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
11/23/2010 5:22:45 PM • Sharp Wizard... • Answered on Nov 23, 2010
0answers
Where is the usb port on the the sharp wizard
Your phone would have came with all the associated cables it needs to connect to a PC. It's not necessarily going to have a 'USB' hole in the phone, there is an 'options' cable slot on the right hand side which will match one of the cables you received in your box, and the other end will be USB for the computer side. Make sure you install all relevant software BEFORE you plug the phone in. If you have windows vista or windows 7, make sure you run the software as administrator. Don't let the disc autorun, close it down, go into Start>computer> and right click on the disc, select 'open' or 'explore' on the disc, right click the phone software and select 'run as administrator'
4/16/2010 2:08:59 AM • Sharp Wizard... • Answered on Apr 16, 2010
When trying to install program
Initially, you might think that the problem is the USB cable. Before you buy a new USB cable, try to isolate the problem first.
Connect the device and the USB cable into different USB port of the computer.
Or might as well, connect it into different computer. If same problem occur, go to the Device Manager of your computer (while the device is connected), and locate the Universal Bus Controllers.
Click the plus (+) sign beside the Universal Bus Controllers, and check if one of the USB devices has a question (?) or exclamation (!) mark. If you find it, right-click on it and go to Properties.
You will see the error message on the status, go to 'Driver's' tab, and click on install driver button.
If same problem occur, try different USB cable.
3/28/2010 9:38:54 PM • Sharp Wizard... • Answered on Mar 28, 2010
My sync sofrware will not download, says I need
MS Outlook is part of the MS Office Suite and is not Outlook Express. Your device may not be disigned to Sync with Outlook Express as the program not have a Calendar function.
You can download a Trial of Outlook from Microsoft at http://us20.office2010beta.microsoft.com/default.aspx
Your device can store the Addresses to the memory of the device itself. See manual here: http://www.sharpusa.com/downloads/archives/product_manuals/org_man_OZ590A.pdf
1/14/2010 11:58:34 PM • Sharp Wizard... • Answered on Jan 14, 2010
Error 0x80040707
installation program error, remove and reinstall the game, maybe you will have to contact your phones vendor worst case- good luck!
8/18/2009 2:06:04 PM • Sharp Wizard... • Answered on Aug 18, 2009
2answers
CANT GET MY SHARP WIZZARD TO DISPLAY THE CURRENT YEAR
If the pda was made in 2005, it's likely that there is a small watch battery somewhere which saves your settings, date, time, etc.
If this "CMOS battery" needs to be replaced, you're probably losing all of those basic settings whenever you let the main battery lose too much of a charge.
Hopefully, it's easy to access.
7/26/2009 11:43:05 PM • Sharp Wizard... • Answered on Jul 26, 2009
Faulty Sreen
It is my understanding that when this happens to your screen, its done, over, trash, use to be, gone, finished, time to go shoping for another, the end.
Understand?
5/5/2009 6:14:58 PM • Sharp Wizard... • Answered on May 05, 2009
0answers
OZ-570
Be the first to answer 4/26/2009 6:44:00 PM • Sharp Wizard... • Posted on Apr 26, 2009Be the first to answer
0answers
Sharp Wizard OZ-590A Logo
41 questions posted
Popular Products
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Wizard Sharp
  • Wizard Sharp
Most Popular Question
sharp wizard oz 590a pc sync
  • Computers & Internet
