20 Most Recent Sharp AR-M207 All-In-One Laser Printer Questions & Answers
2answers
Please my sharp AR-M207 is showing error code L4-11 please I need help please
Use SIM 03-11 to check the shifter motor operations. Check connection of the harness/connector of the shifter motor. Replace the shifter motor. Replace the MCU PWB.
8/15/2022 11:17:47 AM • Sharp AR-M207... • Answered on Aug 15, 2022
SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
6/28/2019 4:21:26 PM • Sharp AR-M207... • Answered on Jun 28, 2019
2answers
Message H2-00 in sharp ar m207
You have an open Thermistor in the fuser unit or the code is false caused by power surge. To reset it, press P*C* and hit 14 start, then hit either ok or start again and machine chould reboot and clear code. If code returns then the thermistor is bad. You will have to have your local dealer replace either the themistor or the entire fuser unit.
2/11/2019 5:26:14 PM • Sharp AR-M207... • Answered on Feb 11, 2019
My sharp AR-M207 is showing error H4.00 call for
Enter simulation mode by pushing # * C * then type 14 and the copy button. The machine will restart and the error code will be gone.
9/28/2018 12:24:20 PM • Sharp AR-M207... • Answered on Sep 28, 2018
Sharp AR-M207 clear paper path
Open all doors move levers inspect that all switch arms are still there. Sometimes when removing paper from copier the switch arm can be knocked lose or off.
5/2/2018 7:38:43 PM • Sharp AR-M207... • Answered on May 02, 2018
Sharp ar-m207 scan to email stopped working
Hi, based on the limited info, the only things I can think you can check are : Your primary & secondary DNS settings, Your Gateway is the same as the router, Your smtp user name & password are re-entered & correct. As a last resort, you could try entering the Gateway address into the primary DNS & try scanning, this would allow the scan to be done without leaving the network & could prove if the problem lies with the smtp acoount. If you're using Gmail to scan then your Primary & secondary DNS are 8.8.8.8 & 8.8.4.4, port number 587. Hope this helps. Dave.
10/18/2017 8:03:43 PM • Sharp AR-M207... • Answered on Oct 18, 2017
HOW TO SOLVE THIS FAULT CODE ON SHARP AR-M207. CALL FOR SERVICE h5-01
Do what it says and call for an authorized Sharp tech.
1/4/2017 4:30:40 PM • Sharp AR-M207... • Answered on Jan 04, 2017
What is the corrective action for a faxing comm error?
depend on the problem does this happen for each fax try different number, check you line, have att come out check the circuit, is the line a analog or digital must be analog, have you called the fax line get a good signal have you plug a old phone into the line and call some one does he sound good no noise. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/30/2016 1:04:19 AM • Sharp AR-M207... • Answered on Jan 30, 2016
Is this the correct place to post questions for Sharp AR-M207 ARM207 Printer/Copier/Scanner/Fax?
Sir, normally you can not get firmware for any copier/printer unless you have access to the companies Secure servers, which house the firmware, Companies like Konica Minola, Sharp want to protect their software, must be a dealer or Corp Technician, Drivers are a totally different story they are normally free at the company web site, and are the best place to go for the most up to date drivers Windows 8.1 10 64 bit etc. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/26/2016 11:56:44 PM • Sharp AR-M207... • Answered on Jan 26, 2016
There is Dark spots on paper when a photocopy is done
Most likely there is something on the glass or something ie: dust underneath the glass that gets in the way of the scanner and the paper(dots) or on the scanner itself(streak). I have heard many times that photocopy machines in cvs/wall greens, any kind of commercial copy places and even libraries deliberately mark on the glass with permanent marker to prevent any kind of copy fraud. You can clean the glass with rubbing alcohol or goof off to remove any stubborn ink on the glass and then use some Windex or something, but if its underneath the glass or on the scanner bar you will need to take some stuff apart clean it and place it back. IF you do that make sure its SUPER clean and you dont leave any finger prints on it
6/17/2015 3:51:44 AM • Sharp AR-M207... • Answered on Jun 17, 2015
4answers
Error: Printing data is inaccurate, printing processing is stopped
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
6/14/2015 9:06:50 AM • Sharp AR-M207... • Answered on Jun 14, 2015
How can I replace developer in my copier?
Wouldn't necessary change the developer, only if it is causing quality issues, maybe your developer light is on, on the machine. Still should be able to use the machine. Cheers
3/19/2015 2:13:02 PM • Sharp AR-M207... • Answered on Mar 19, 2015
How do i fix a sharp copier that is close but still indicating close cover
The sensor that tells the machine that the cover is open may be broken. I'd recommend calling a certified Sharp service company and having them fix it, it should be a quick fix. http://www.sharpusa.com/CustomerSupport/ServiceLocator.aspx Copier Collin Houston TX Copier and Imaging Expert
2/10/2015 3:11:46 PM • Sharp AR-M207... • Answered on Feb 10, 2015
Sharp AR-M207 All-In-One Laser Printer Logo
121 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
error printing data inaccurate
  • Office Equipment & Supplies
