20 Most Recent Sharp AL-1661CS All-In-One Laser Printer Questions & Answers
Fax machine won't fax out
You have the phone line from your wall plugged into the headset and not into the machine.
4/24/2018 4:15:18 PM • Sharp AL-1661CS... • Answered on Apr 24, 2018
We continually get a paper
Hi browngrand,
If the misfeed light does not go out, please look for any torn pieces of paper inside the machine leading from the bypass tray and remove them.
Please follow the steps below to correct the problem.
1.
2.
3.
4.
5.
6.
7.
Hope it helps.
Thank you for using FixYa.
9/16/2011 12:48:09 AM • Sharp AL-1661CS... • Answered on Sep 16, 2011
0answers
ERROR L1-00 EN SHARP AL1661CS
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
5/25/2011 11:32:33 AM • Sharp AL-1661CS... • Answered on May 25, 2011
HOW CAN I MAKE MY
With Win7 Pro, you can download and install two programs from Microsoft. You need Virtual PC and XP mode. Download and install them in order from http://www.microsoft.com/windows/virtual-pc/download.aspx . You will have to assign an amount of memory to dedicate to the XP computer during the setup. Then open the program and install your laser printer to the new virtual XP computer on your Win7 machine as you normally would install the printer to XP. If you need the drivers, they are available here: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=Driver&category=HomeOfficePrintersFaxMachines&model=AL-1661CS& .
However, your files can't be shared directly. You will need to save them to external media (optical disc or flash drive) and then transfer them.
I hope this helps.
(I've got XP mode on one of two Win7 Pro computers in my facility)
2/24/2011 2:12:32 AM • Sharp AL-1661CS... • Answered on Feb 24, 2011
2answers
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
10/31/2010 11:35:55 AM • Sharp AL-1661CS... • Answered on Oct 31, 2010
0answers
Get a grinding noise when you turn the printer on
is ur printer is silent earlyar if its open top cover clean dust check for small paper pices or jamed
6/25/2010 7:05:56 PM • Sharp AL-1661CS... • Answered on Jun 25, 2010
Drivers windows seven
From the research I have done it looks like the drivers for that printer are actually in the Windows 7 driver data base. It should be able to automatically install the printer when you attach it via USB.
6/18/2010 10:08:50 PM • Sharp AL-1661CS... • Answered on Jun 18, 2010
Sharp al 1661 cs ..it shows System error(L1-00
I have posted a tip covering this code here on Fixya. Here is the link to it so that you may find a solution for your L1 code.
Good Luck and Thank You for using Fixya.
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
6/10/2010 4:06:15 PM • Sharp AL-1661CS... • Answered on Jun 10, 2010
Sharp code h3-00
heat roller high tempareture detection
5/24/2010 12:42:14 PM • Sharp AL-1661CS... • Answered on May 24, 2010
0answers
0answers
2answers
Dificcult to find the driver?
Click here for driver
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
4/9/2010 12:45:18 AM • Sharp AL-1661CS... • Answered on Apr 09, 2010
I would like to know if there are drivers for
Hi, go to the website “touslesdrivers.com”. Click the link “mes drivers” on your left / click “lancer detection” at the bottom” . Now the website will propose you to allow installation of a pluggin (active x) to scan your laptop for proposing drivers. Pls allow.
Then choose the ones which are missing & follow hyper link to download the exact latest driver for your hardware. Well, that’s it. Ur problem will be surely solved.
2/10/2010 6:54:13 PM • Sharp AL-1661CS... • Answered on Feb 10, 2010
Sharp al 1661 cs ..it shows System error(L1-00)
When your copier scanner is locked then show L1
Solve :Unlock position
clean all surface in scanner area
clean scanner sensor
1/2/2010 6:45:44 PM • Sharp AL-1661CS... • Answered on Jan 02, 2010
Printer is giving a message as system error L1-00
erro LSU
11/10/2009 9:17:49 PM • Sharp AL-1661CS... • Answered on Nov 10, 2009
Sharp AL-1661CS All-In-One Laser Printer Logo
43 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
AL Sharp
  • AL Sharp
Most Popular Question
error l1 00 en sharp al1661cs
  • Office Equipment & Supplies
