20 Most Recent
LG Wm3470hva Wm3470hva Front Load Washer Questions & Answers
Wm3470hva no power
Unplug the washer from the wall wait about 5 minutes, plug it back in to the wall and press the power button. You should see all of the lights on the front come on and start cycling. wait about 2 minutes and you should be ready to start washing.
When I started my washer wm3470hve for first time
6his can happen when you either overload the washer or you have a low amount of stuff in but it is heavy. would seem 4.0 is the max you can have in the drum at a time. if it persists at this with varying loads. then the shockers have gone weak and need replacing. or the drum has come out off balance. this can because of the bearing or something has dented the drum. somtimes putting shoes in to was can do this type of damaged.
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
