20 Most Recent
Roper 24 in. RUD4000M Built-in Dishwasher Questions & Answers
Copier - canon np6010
to stop this Bay chip reset software from ebay or another place for
Canon
http://cgi.ebay.in/ws/eBayISAPI.dll?ViewItem&item=110521860863
its working and very low cost at just 2 dollers and 99 rupies
Water leaking through vent in door
Check your spray arm that nothing got stuck in its holes. make sure the
spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
Dishwasher Detergent Dispenser not opening
An automatic
dishwasher
detergent dispenser door can become stuck for a few different reasons.
Some problems are easy to fix, while some require more work. Repairs
are basically the same no matter what brand of automatic dishwasher you
have, although specific parts might be required. Fortunately, even if
the detergent dispenser needs to be replaced, the problem is not an
emergency. The dishwasher will clean dishes fine even with a stuck
detergent dispenser.
Fixing a Stuck Automatic Dishwasher Detergent Dispenser
Step 1
Move
the basket that holds silverware as far from the detergent dispenser as
possible, or make sure no tall items are blocking the dispenser. Also,
keep other items such as plates and pans away from the dispenser.
Anything that winds up touching the dispenser during the wash cycle can
cause the dispenser door to stay closed. Run the dishwasher to see if
this solves the problem.
Step 2
Remove
the front door panel according to your instruction manual, or find the
manufacturer's instructions online, which will probably be in a PDF
file. The panel is typically held on by 6 to 8 screws along the edge,
which you can see when the door is open. With most models, you won't
need to remove the screws at the bottom of the door, which are part of
the hinge assembly.
Step 3
Clean
the detergent dispenser thoroughly from the inside of the dishwasher
and the exterior side as well. Accumulated detergent and other material
can interfere with the spring mechanism or halt the pivot action of the
door. Use very hot water and a micro-sized brush. You also can use a
mix of hot water and vinegar.
Step 4
Most
dispensers have a bimetallic strip or switch, attached by screws, which
triggers the door release. With the front door panel removed, locate
the switch, and push on it gently with a screwdriver until the
dispenser door opens. You might simply need to adjust the alignment of
the switch.
Step 5
Purchase
a new switch if re-aligning the old one does not fix the problem.
Typically, these switches cost under $10. See Resources for a link to
different manufacturers where you can buy the part.
Step 6
Label
the two wires connected to the switch so you can correctly reconnect
them afterward, and then remove them from the terminals by holding the
slip-on connectors --- not the wires --- and pulling firmly. Use a pair
of needle-nosed pliers for a better grip. Then remove the switch from
the dispenser by removing the screws holding it in place. Connect the
wires to the terminals of the new switch, and attach the new switch to
the detergent dispenser. Replace the door panel.
Step 7
Run
the dishwasher again to see if the switch replacement has done the
trick. If not, decide whether to replace the entire dispenser according
to the manufacturer's instructions, or call a repair technician.
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Dishwasher on no water
Is the water valve under the sink on? Any kinks in the hose? Check to see if the water valve solenoid coil is open (located under the cabinet front).
Dishwasher water level low and making strange noise.
Hi, This d/w is designed to run with low water level. The noise you are hearing might be the wash motor. Do you know if this has the single or dual motor setup?
The dual motor style are not the greatest. The wash motor is known to go bad. You can remove the housing below the spray arm and see if anything has lodge in the in impeller. Please let me know if I can assist you further.
Vic
Jenn air dishwasher- making loud noise in operating cycle
Hi I am Vortash by the sound of what you are descibing your pump bearings seem to be shot , although it is making this sound is it still washing properly if so it confirms it is the bearing and not the impeller catching and making the noise the pump gets to quite a high pressure to wash the dishes .. sort of an enclosed hot jet wash the force of which drives the spray arms .. so I am afraid it looks like you will soon need a replacement pump.. sorry to bare bad news .. Regards Vortash
