20 Most Recent Bosch "NGM Series 30"" Gas Cooktop" Questions & Answers
Bosch induction not working
Very specialised high tech tops need engineers to fix. It is likely to be the power board. https://www.google.com/search?q=Schott+Ceran+stove+top+with+5+induction+hobs+no+power ..
12/9/2023 7:11:31 PM • Bosch Cooktops • Answered on Dec 09, 2023
Bosch oven display does not work at all but the cooktop works. what is the problem?
There could be a few different reasons why the display on your Bosch oven is not working, but the cooktop is functioning properly. Some possible causes include:
  1. A problem with the control panel: The control panel is responsible for controlling the oven and displaying information on the screen. If there is a problem with the control panel, it may be preventing the display from functioning properly.
  2. An issue with the oven's electrical system: If there is a problem with the oven's electrical system, it could be causing the display to malfunction. This could be due to a problem with the wiring, a faulty component, or a power issue.
  3. A problem with the display itself: It is also possible that there is a problem with the display itself, such as a damaged screen or a malfunctioning component.
In order to determine the cause of the problem and fix it, you will likely need to have the oven inspected by a professional appliance repair technician. They will be able to diagnose the issue and recommend the appropriate course of action.
1/6/2023 11:01:32 PM • Bosch Cooktops • Answered on Jan 06, 2023
Bosch Induction cooktop#NIT8665UC error code 3d or d3 at burner indicator
Did you ever get an answer to this? Same problem :(
7/27/2021 10:11:29 PM • Bosch Cooktops • Answered on Jul 27, 2021
2answers
Bosch induction cook top flashing F 9 snd will not work
https://www.fixya.com/support/t27212586-f9_code_flashing_bosch_induction_cook
1/24/2021 6:24:32 PM • Bosch Cooktops • Answered on Jan 24, 2021
I have a Bosch cooktop induction and the model is Nit5665uc/02. IT was purchased in 2011. It is displaying a e 1 on the 2 right side burners.
https://www.bosch-home.ca/en/search-result?search=Bosch%20cooktop%20induction%20model%20is%20Nit5665uc/02.%20%20It%20is%20displaying%20a%20error%20e%201&tab=content
4/16/2020 3:01:57 PM • Bosch Cooktops • Answered on Apr 16, 2020
I have a Bosch PKG775DB1Y electric cooktop. It won't turn ON. I am NOT in Lock mode. After I disconnect power for a few seconds it starts working OK. Randomly the problem will return. Any ideas?
By far the most common cause of what you describe is Demo Mode is turned ON 1-bq0fxqg1zh3iovhrefhl5oob-1-0_1.jpg If am certain you have already checked to make certain there are not too many appliances plugged into the same outlet, and that you are not trying to run your Bosch through a power strip or so-called "surge protector", which are worthless troublemakers.
4/21/2019 9:09:32 PM • Bosch Cooktops • Answered on Apr 21, 2019
F9 code flashing on Bosch induction cook top
JENN AIR 'Newer Style' Range/Stove/Oven Fault Codes Fault : F9 Condition: Door lock safety circuit on power relay board sensed Replace power relay board JENN AIR Range/Stove/Oven Fault Codes Fault:F9 Condition: Door latch supervisory Check door lock circuit or replace clock assembly or ERC
2/2/2019 8:40:27 PM • Bosch Cooktops • Answered on Feb 02, 2019
Bosch cooktop Flashing F9
again.
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. From the Manufacturer
2/2/2019 8:04:20 PM • Bosch Cooktops • Answered on Feb 02, 2019
I have a Bosch 30" induction cooktop that has stopped working with no error codes.
Dear Ed, Sounds like you have a short, perhaps in the cooktop control panel. Please do not even try to get it to work again until it is checked by an electrician, so you do not find your self fighting a fire somewhere between the circuit breaker box and the cooktop. God bless your efforts.
6/1/2018 8:55:37 PM • Bosch Cooktops • Answered on Jun 01, 2018
I have a Bosch model 8054 gas cooktop and the decals under the knobs are worn away, any ideas for replacements , called Bosch. They said they don't have replacement decals
Hello -I found some suggestions in an answer to a similar question for a different make of gas cook top. One of the suggestions here may be one you would wish to follow:http://forums.whirlpool.net.au/archive/1772463Best wishes.
1/11/2018 6:41:01 PM • Bosch Cooktops • Answered on Jan 11, 2018
I have a Bosch Schott Ceran Induction Hob model number ********** and need the manual. Where do I get one please
Try to do a search on the Internet, something like: Manual Bosch + your model number. I have usually had good luck finding a free download. Sometimes there are downloads also available directly on the manufacturer's website as well.
12/23/2017 3:20:33 PM • Bosch Cooktops • Answered on Dec 23, 2017
Igniters on my Bosch gas cooktop not working. I guess it needs cleaning. How do I do it?
You can try to clean the two pins with degreaser and then soap and water using a skrubby sponge for delicate surfaces However, my Bosch cooktop has had problems with the igniters (particularly on two burners) which required the replacement of the control unit. This requires opening the unit completely and replacing the white plastic box and connections to each burner. It is easy enough to do, but it is a bit scary to lift off the glass as there is probably an adhesive which one has to lift the top off of. Another thing you can try is to adjust the two screws that are uderneath the removable cover of the burner. Sometimes just tightening or loosening them a bit can solve the problem
12/23/2017 3:16:49 PM • Bosch Cooktops • Answered on Dec 23, 2017
I have a Bosch Induction cooktop with the child lock stuck on - how do I get it off?
I hope this helps. If not, provide your model number. Best wishes.
11/23/2017 3:31:05 AM • Bosch Cooktops • Answered on Nov 23, 2017
Bosch "NGM Series 30"" Gas Cooktop" Logo
0 questions posted
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Bosch Cooktops
  • Bosch Cooktops
Most Popular Question
bosch induction not working
  • Cooktops
