20 Most Recent
Acer Extensa 503T Notebook Questions & Answers
Ihave an acer extensa 5220 but no webcam driver.
If u got no install disk with the webcam, visit the companys' web site.
The driver should be available to download from there.
Failing that, input a search on the internet for:" acer extensa 503 webcam drivers".
Do not download from Google ads...and find one that is free.
Wishing you success.
What for a kind of
It looks like your device is a SATA device, if it is, the IDE drive will not fir and there is no adapter that I am aware of.
Try;
http://www.laptopbits.co.uk/Database_files/Acer_Laptop_Replacement_hard_drive.htm
for clarification.
Acer laptop crack at the back of LCD near the hinges.
In my experience, I have been able to replace the LCD Bezel to fix the crack. You can order this from any online parts store if you are a Do-It-Yourself type or any computer support company could help. Good Luck
Frank
Reboot
I need more information about the condition as we may not have to totally delete and reinstall software. Have you tried to safe boot and then do a restore under accessories-system-tools-restore?
What have you installed lately?
I keep getting a high-pitched squeal from my left
Do you have a microphone or a magnet near where this squeal is coming from?
If no to the above, it sounds like you have a mic crossed wire inside, "if" you haven't had any new software installed before this started, The easiest thing is to delete and reload a new audio driver, that's where I would start.
My acer extensa 5220 is overheating
Either CPU is faulty, or the heatsink has lost aderence with the CPU surface or coolin power.
Atandard procedure is refitting or replacing cooling fan, in some rare occasion is the CPU, but that is uncommon and can't be tested.
Another possible cause is the temp sensor on the motherboard that is faulty.
first ensure that is overheating and check temp sensor using
SpeedFan - Access temperature sensor in your computer.Good luck.
G.
I only get a key symbol when it starts up
My suggestion would be to try flashing (reload) the bios. You should be able to find a utility from your PC or motherboard manufacturer's website that allows you to create a bootable disk for this purpose.
