20 Most Recent
Transparent Easy Translator 4 Deluxe for PC Questions & Answers
Years ago I bought Easy Translator 4 deluxe at
Trying running the Install program in Compatibility mode and running the program in Compatibility mode for Win XP it should allow that. If not it is going to be an issue of your using a 64 bit version of Windows now and your software was designed for a 32 or 16 bit environment. You could check the program manufacturer website to see if there is an update or patch for it as a last resort. 64 Bit versions of Windows don't like to cooperate with 16 and 32 bit programs even when they were programs designed to run on Windows as a platform.
A unknown error has occured. The application will
When poeple create software, they test it in order to discover programming errors, and all sorts of unusual conditions that may make the software misbehave. For every error found they design a customized message to let you the user know what happened and what you can do to salvage your work.
Error conditions may also be created by the user and the input he/she gave the software. In the testing phase, the testers try to think of all possible data (good and garbage) that the user may enter and design a message if the input leads to a software misbehavior.
But programmers and testers are not omnicient and sometimes they miss errors conditions. For all these, there is message telling you that an unknown error happened.
You may reduce the number of such occurences by familiarizing yourself with the software and its use.
Hope it helps.
In which version of MA5600 We can transparent the igmp over pppoe packet
Customer wants to use PPPOE connection to connect to the BRAS . The version of the
Huawei MA5600 is V3R2B02D108
and they want to know that this version supports this function .
Alarm Information
Null
Handling Process
A:After confirming with R&D we confirm that V3R3C03B029 and V3R2B02D260 supports transparenting the igmp over pppoe packet . The recommended one is V3R2B02D260 so We asked customer to upgrade to this version to support the needed function.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
