20 Most Recent Braun Wk600 Impressions 7-cup Electric Kettle, Brushed Stainless Steel Questions & Answers
0answers
0answers
0answers
Water is leaking from the bottom
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is above the heating area. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees so that you have a new high point and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You mayl have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealants that were:
1. Potable (ie safe since you will be using the water for coffee, tea, and other applications that you ingest).
2. That will withstand heat up to at least 250 degrees Fahrenheit. Remember that water boils at 212 degrees.
I found epoxies that required mixing two compounds but decided that this would be difficult to deal with and apply. In the end I bought "PC Plumbing Epoxy Putty" from PC-Products. This met both requirements and was easy yo use. You take the putty and roll it between your finger just like you did in kindergarten with the clay and make a thin string that you could position in the crevice around the top of the heating area. You may either cover the area where you found the leak or the entire 360 degrees. You will note a somewhat foul smell of the putty. The manufacturers says that it will cure in 3 hours. I found that the smell went away when it completely dried and hardened after 3 weeks!.
I will assume that the same solution is applicable to leaks in other areas of the kettle. I have also found that there are equivalent electric kettles much cheaper than Krups. I would certainly check the construction to see if there is one with less of a chance to develop a leak.
But the bottom line is that it cost me $4. I just finished testing the Electric Kettle and it is fine, not leaking, and the instant coffee did not have any bad smell.
Meir Elazar
2/12/2011 11:08:02 PM • Braun Kitchen... • Answered on Feb 12, 2011
I am having problems with
This can be that you need a goo cleaning of the toaster. It is possible that Bread crumps and toasted crumps has hardened and got deposited on the tracks of the hinges and carriage.
So you will need to remove the unit and see the tracks of the carriage to which it moves.
Clean the portions with some edible oil and dry wipe them off.
Make sure in this process that the carriage is manually moved for free movement.
1/31/2011 5:30:59 AM • Braun Kitchen... • Answered on Jan 31, 2011
Where can I get a REPAIR MANUAL FOR COOKS TXG-DT16A please?
Unfortunately nowhere. These are a budget item sold by QVC and JC Penney and there is no support. https://www.google.com/search?q=COOkS+txg-dt16A+repair+manual Parts, except there isn't any. https://www.google.com/search?q=COOkS+txg-dt16A+parts ....
4/15/2024 12:18:24 AM • Kitchen... • Answered Yesterday
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM • Kitchen... • Answered Yesterday
Waring Commercial CTS1000 Conveyer Toaster, 450 slices per hour. I need to find a wiring diagram for a CTS1000 toaster, please?
Question edited for a lot more clarity, full 'make model what it is)'. No wiring diagram on line, just operating manual and parts list. Contact Waring Support direct.
CTS1000B-1 copy
Waring Commercial Products https://www.waringcommercialproducts.com > files PDF Jun 10, 2020 - Illustration # Part #. Description. 1. 028863. Crumb Tray. 2. 029683. Conveyor Belt. 3. 028864. Toaster Drawer.
CTS1000-1 copy
Waring Commercial Products https://www.waringcommercialproducts.com > files PDF Jun 27, 2018 - Toaster Drawer (on units after 1/5/2012). 028864. Toaster Drawer. 3. 028865 Foot (4 required). 4. 029683. Conveyor Belt. 5. 029684. Red LED ...
CTS1000 Parts list
WebstaurantStore https://www.webstaurantstore.com > diagram > ct... PDF CTS1000. CTS10006. CTS1000C. Waring Factory Service Center. 314 Ella T. Grasso Ave. Torrington, CT 06790. Tele. 1-800-269-6640. Fax 860-496-9017 https://www.google.com/search?q=waring+cts1000+toaster+wiring+diagram ..
4/11/2024 6:30:59 PM • Kitchen... • Answered on Apr 11, 2024
Siemens porsche toaster bread wont stay down
https://www.youtube.com/watch?v=YuVA3aDcJeA&ab_channel=MyMateVINCE
3/27/2024 4:37:36 PM • Kitchen... • Answered on Mar 27, 2024
Need manual for eqyitytime model 31429E, thanks.
This might help but the model number quoted does not exist as far as I can tell. https://www.youtube.com/watch?v=RETajMxnT4E
3/24/2024 12:11:15 PM • Kitchen... • Answered on Mar 24, 2024
Braun Wk600 Impressions 7-cup Electric Kettle, Brushed Stainless Steel Logo
1 questions posted
Top Braun Kitchen Appliances - Others Experts
john h
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Braun Kitchen Appliances - Others
Most Popular Question
braun electric kettle click
  • Kitchen Appliances - Others
