20 Most Recent Roper FES330 Electric Kitchen Range Questions & Answers
Roper ES330KQ manual
http://www.manualsonline.com/
11/29/2012 9:57:26 PM • Roper FES330... • Answered on Nov 29, 2012
Roper stove fes330 - element
One of the four burner switches has a stuck contact causing the indicatorlight to stay on. There are two types of infinite switches used in electricranges. Each one of the terminals on infinite switches is labeled. When theinfinite switch is turned to the ON position, terminal "P" contactcloses and completes a voltage path to the Pilot light and it glows. You canuse the process of elimination to find which switch is bad. Turn the breakeroff inside your house breaker box dedicated for the range or if it has a powercord you can unplug it. Once the voltage supply has be disconnected to therange, remove the control panel and disconnect just the one wire connected toterminal "P" and then turn the power back on. If the light stays off,replace that switch. If the light comes back on, disconnect power again andthen go to the next switch and remove the wire on terminal "P" andrepeat these steps until the light stays OFF and then you found the bad switch. Remember to disconnect thepower supply before removing and reinstalling the wires back onto terminal"P". Hope thiswill help you. Good Luck.
7/7/2011 2:21:35 PM • Roper FES330... • Answered on Jul 07, 2011
We have a Roper model # FES340YW-2 electric stove,
bad thermo switch
10/30/2010 1:52:59 PM • Roper FES330... • Answered on Oct 30, 2010
0answers
When I try to bake in my oven, I cannot get the
If your range is gas then the model would be FGS330. The thermostat is failing to tell the oven to cycle off. Replace the thermostat.
Tom
8/12/2010 2:25:03 AM • Roper FES330... • Answered on Aug 12, 2010
Grease fire in oven. elements would not come back
First verify 220 volts to the range where the cord connects.
Second,unplug the range and remove the element again and using a volt/ohm meter set for ohms or continuity check the element. No reading is a bad element.
Third, if power is OK and the element reads continuity check for power in at the oven control in the control panel.
Set for Bake and check power Out of the oven control.
No power out is a bad element.
If the control is OK,remove the oven temperature sensor and with the meter check for 1100 ohms +or- 25 ohms.
If not correct,replace the temp sensor.
3/18/2010 12:50:11 PM • Roper FES330... • Answered on Mar 18, 2010
My Roper FES330 oven door just came off the hinges
Set the hinges to where they will be in the position of broil. Ease the door back onto the hinges at that angle.Keeping the door even as you gently slide it home, then push the door closed. Simple If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
11/4/2009 4:46:35 AM • Roper FES330... • Answered on Nov 04, 2009
Fes330 roper stove
you have no heat at all? K, pull stove out and check how many volts you have should be 240. Your elements work off 240 if you only have 120 coming to stove the lights will work jujst not your heat. You should have a double pole 40amp breaker If you only have 120 change the breaker
8/31/2009 4:21:17 PM • Roper FES330... • Answered on Aug 31, 2009
0answers
E 2 and F3 error, beeping
What is the model number?
5/1/2014 1:23:09 AM • Roper Kitchen... • Answered on May 01, 2014
0answers
0answers
Roper FES330 Electric Kitchen Range Logo
Popular Tags
21 questions posted
Top Roper Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Roper Kitchen Ranges
Most Popular Question
roper fes330 oven door just came off
  • Kitchen Ranges
