20 Most Recent LG LP076HD3A Packaged Terminal Air Conditioner PTAC, A/C & Heat Pu Questions & Answers
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
2/19/2015 4:42:41 PM • LG LP076HD3A... • Answered on Feb 19, 2015
4answers
My LG air conditioner is saying water fl what is that and where can I find it? I cannot find the book.
The FL error usually means that there is excess water in the drain pan. Look for the drain plug cap at the bottom of the back of the air conditioner. Remove the cap and tilt the air conditioner so that any water in the drain pan will run out. If the room is extremely humid and the air conditioner is set to Cool, this is normal. To reduce the water level issue, set the fan speed to Low. If the air conditioner is in the Dry (dehumidifying) mode, try setting it to Cool. Alternatively, consider using a hose if your unit allows for a continuous drain. Unplug the air conditioner for at least 10 seconds to reset the unit if the error persists. If the drain pan is dry or the error recurs before more water fills the drain pan after the reset, then the air conditioner needs service. Please add a comment with the model number of the unit if you need help finding the drain pan cap. I hope this helps. Cindy Wells
4/23/2024 5:57:52 AM • LG Heating &... • Answered Yesterday
CH21 error on LG - 800 Sq. Ft. 14,000 BTU Smart Window Air Conditioner (model LW1522IVSM).
The error is that the DC voltage is too high, not the house AC voltage. It should regulate through a transformer. Get LG to send an engineer under warranty. If you have a multimeter, you can test your house voltage. DC peak error / IPM fault; compressor DC voltage was too high.
DEFINING COMMON ERROR CODES
LG HVAC https://lghvac.com > resource-service > filename=... PDF DC peak error / IPM fault; compressor DC voltage was too high. 2X. 1X. 22. Current transformer2 (CT2) error; AC input current is too high. 2X. 2X. 23. DC link ... https://www.google.com/search?q=LG+AC+CH21+error ..
3/31/2024 6:42:12 PM • LG Heating &... • Answered on Mar 31, 2024
2answers
I have error code ch 09 displaying on my
The error codes are not all the same. They are different for different models.
THIS IS NOT A SOLUTION....
This is a "Clarification request"
Can you please locate and post your LG model number here so we can help you properly and professionally.
1/19/2024 10:12:44 AM • LG Heating &... • Answered on Jan 19, 2024
2answers
LG air conditioner
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Also What is the model of your air conditioner. With out that information i cant help you with your ac repair problem Check us out online at AC Service Delray Beach Fl
1/17/2024 7:36:35 AM • LG Heating &... • Answered on Jan 17, 2024
2answers
I have a LG air conditioner which seems stuck on defrost. It works fine in cooling but when on heat the defrost light comes.
Possibly a stuck or closed defrost sensor. The sensor gets to freezing which closes the switch. So the unit goes into defrost cycle which switches the flow of the freon on a Heatpump. The hot gas thaws the coil and the sensor. Which opens the switch and switches it back. I'm giving this answer without knowing more about the unit. Defrost light comes on & it doesn't run at all? LG system is a split unit or window unit or what? If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_868a5ee3bf9eea64
11/20/2023 9:45:38 AM • LG Heating &... • Answered on Nov 20, 2023
Foutcode ch 24 bij LG airco
Question edited for clarity and translated to English. A CH 24 error code indicates a pressure switch error. To Resolve: Make sure the air filter in the unit is clean. Remove any items or reposition the unit so that the air flow is not obstructed. Apr 25, 2023
LG Dehumidifier - Error Code List ' LG USA Support
11/15/2023 4:34:40 PM • LG Heating &... • Answered on Nov 15, 2023
2answers
Lg dual inverter stuck in defrost
It sounds like you were experiencing an issue with one of the indoor units on your LG dual inverter air conditioner, where it was stuck in defrost mode while the other unit was working properly in heating mode. It sounds like you've already replaced the control board of the indoor unit that was stuck in defrost mode and it fixed the problem. The control board is responsible for controlling the various functions of the air conditioner and it is a common cause of malfunction in air conditioning systems. It's great that you've been able to fix the issue, but if the problem comes back or you're experiencing other issues, it's best to contact LG's customer service or a professional technician for further assistance. It's important to note that troubleshooting and repairing air conditioners can be dangerous, especially if you're not familiar with the device, so it's best to contact a professional technician if you're not comfortable working with it.
10/9/2023 10:27:20 AM • LG Heating &... • Answered on Oct 09, 2023
LG 4 zone Mini Split error - CH35 triggered with specific Wall Mount.
These units cool better than they heat, and if the temperature ever drops far into minus 'C digits, they don't work at all. I have found that turning off all power for a minimum of two hours will reset most errors,. When you switch the breaker back on, you will hear relays clicking as part of the self testing. Wait 15 minutes before operating the unit. It sounds like your installer doesn't want to deal with you any longer. The engineers get very basic LG Service training, so at stages they are completely lost. I was advised not to buy LG and went with Fujitsu, but they have their own problems as it seems they all do! Phone LG Support on Monday and ask their advice, don't let them just say call for service. Tell them you want to speak with a technician that does the training sessions and seminars. ..
10/8/2023 1:24:53 AM • LG Heating &... • Answered on Oct 08, 2023
LG Art Cool Gallery version A12AW1 won't start heating?
Question edited for clarity and spelling 'Gallery' and toss in some CAPS. Question moved from LG Office Equipment Category. Sorry for the delay in getting back to your question. Try disconnecting the power at the breaker for at least 2 hours and preferably overnight. This fully resets the units and it will do a Self Test when you switch it back on. Wait 15 minutes before operating it. 5 Blinks is a loss of communication.
Fault Codes for all LG wall mounted and Artcool split system
airfusion.co.uk https://www.airfusion.co.uk > fault-codes-all-lg-wall-... Fault code C5, CH5 or 5 flashes This fault code indicates a communication error between the indoor and outdoor units. If there is a communication error fault ... Missing: stops ‎' Show results with: stops People also ask Why is my LG cooling light flashing 5 times?"); display: inline-block; height: 24px; width: 24px;"> Why is the light flashing on my LG air conditioner?"); display: inline-block; height: 24px; width: 24px;"> How do I reset my LG air conditioner?"); display: inline-block; height: 24px; width: 24px;"> What is E5 error on LG portable AC?"); display: inline-block; height: 24px; width: 24px;"> Feedback
[LG Air-Conditioner Error Codes] Checking code CH53
LG Electronics https://www.lg.com > Home > Support Home Jun 9, 2023 - The second LED indicates error at 10's digit. Ex) After the second LED blinks 3 times with certain interval, if the first LED blinks 5 times . ..
10/8/2023 12:19:51 AM • LG Heating &... • Answered on Oct 08, 2023
My lg split ac non inverter is working fine but missing command beep
  1. Check the remote control: Look for a button on your remote control labeled "Beep" or "Sound". Press this button to turn the beep sound back on .
  2. Check the settings: If you can't find a "Beep" or "Sound" button on your remote control, check the settings menu on your AC unit. Look for an option to turn the beep sound on or off and make sure it's turned on .
  3. Reset the AC unit: If neither of these steps work, try resetting your AC unit to its factory default settings. To do this, turn off the AC unit and unplug it from the power outlet. Wait for a few minutes and then plug it back in and turn it on .
If none of these steps work, it's best to contact a professional or LG's service center for further assistance. I hope this helps!
8/27/2023 3:26:56 PM • LG Heating &... • Answered on Aug 27, 2023
CH 60 erfor LG aircondition
8/12/2023 5:26:23 AM • LG Heating &... • Answered on Aug 12, 2023
LG Portable AC has E9 error code displayed.How to fix this?
have you cleaned filter a regular basis? dirty filters will cause low air circulation. go to long and the evaporator coil is dirty and plugged and will require cleaning. There is no E9 code listed the E5 code describes what you have. Have you been emptying water collection tank? https://www.lg.com/ca_en/support/product/lg-LP0821GSB
7/14/2023 3:41:22 AM • LG Heating &... • Answered on Jul 14, 2023
LG portable air conditioner is making loud squealing noises
Maybe a bad blower motor. Or a dirty one (wheel) causing the wheel to be outa balance.https://www.repairclinic.com/ProductDetail/1147658?symptoms=92Parts too....https://encompass.com/model/ZENLP0711WNR/AWYAOSU
6/3/2023 6:00:22 PM • LG Heating &... • Answered on Jun 03, 2023
LG Multi V III VRF Heat Pump is showing 79 in the odu.
Question edited for a lot more clarity, full maker, model (what is is). No idea what an 'odu' is though?? Question moved from Computers and Internet category to LG. Outdoor unit fan operation error. Page 178 of the Service Manual refers
SERVICE MANUAL
LG HVAC https://lghvac.com > resource-service > filename=... PDF The instructions included in this manual must be followed to prevent product malfunction, property damage, injury, or ***** to the user or other people. 235 pages
5/11/2023 5:19:18 PM • LG Heating &... • Answered on May 11, 2023
LG MINI SPLIT LMU540HV multi-zone. - Seems like wires got crossed on 2 out of 6 Indoor units.
The way to reset these units is to turn off at the breaker for at least 2 hours and preferably overnight. It does have an internal PCB reset button that is mentioned in the Service Manual. It is a VERY complicated system! https://www.google.com/search?q=LG+MINI+SPLIT+LMU540HV+reset ..
5/10/2023 6:06:41 PM • LG Heating &... • Answered on May 10, 2023
LG Microwave MG 6045WB - turn table not rotating
If the turntable in your LG microwave (model MG 6045WB) is not rotating even after replacing the motor, there could be a few other possible causes. Here are some troubleshooting steps you can try:
  1. Check the turntable guide: The turntable guide is a small plastic piece that fits under the turntable and keeps it centered. If this guide is worn or broken, it could prevent the turntable from rotating. Check the guide and replace it if necessary.
  2. Inspect the turntable motor coupler: The coupler connects the motor shaft to the turntable. If this coupler is worn or broken, the motor will not be able to turn the turntable. Inspect the coupler and replace it if necessary.
  3. Test the door switch: The door switch is a safety feature that prevents the microwave from operating when the door is open. If the door switch is faulty or not aligned properly, it can prevent the turntable from rotating. Test the door switch and replace it if necessary.
  4. Check the control board: The control board is responsible for sending power to the turntable motor. If the control board is faulty, it may not be sending power to the motor. Check the control board and replace it if necessary.
If none of these troubleshooting steps resolve the issue, it may be best to contact a professional for further diagnosis and repair.
3/3/2023 11:36:36 AM • LG Heating &... • Answered on Mar 03, 2023
Having a defrost problem with my LG refrigerator. The heater is 348 Ohms. Do I need to replace the heater
If you are supplying direct current to the heater coil and it is not heating up, then it is likely that the heater coil is faulty and needs to be replaced. The fact that the resistance of the heater coil is 348 ohms suggests that it may be within the expected range for the heater, but this alone does not guarantee that the heater is functioning properly. Before replacing the heater coil, however, it is important to ensure that there are no other issues with the defrost system. For example, a faulty defrost thermostat or defrost timer can also cause defrost problems in a refrigerator. It is recommended that you consult with a qualified technician or the manufacturer of your LG refrigerator for assistance in diagnosing and repairing the defrost problem. They will be able to provide more specific guidance on what steps to take next to resolve the issue.
2/23/2023 4:38:05 AM • LG Heating &... • Answered on Feb 23, 2023
I have a LG LP120CED Ptac AC displaying an FP code. How can I disable the Freeze Protection on this unit?
Le code d'erreur « FP » sur un climatiseur LG LP120CED signifie que la fonction de protection contre le gel est activ?e. Cette fonction est con?ue pour prot?ger l'appareil contre les dommages caus?s par le gel, en arr?tant le compresseur lorsque la temp?rature ambiante est trop basse Pour d?sactiver cette fonction de protection contre le gel, vous pouvez suivre les ?tapes suivantes : Appuyez sur le bouton « On/Off » pour mettre l'appareil hors tension. Appuyez sur les boutons « Mode » et « Temp?rature » simultan?ment et d?placez-les pendant environ 3 ? 5 secondes. La lettre « FP » devrait clignoter sur l'affichage. Appuyez sur le bouton « Mode » pour d?sactiver la fonction de protection contre le gel. La lettre « FP » devrait dispara?tre de l'affichage et l'appareil devrait fonctionner normalement. Si vous rencontrez des difficult?s pour d?sactiver la fonction de protection contre le gel, vous pouvez consulter le manuel d'utilisation de l'appareil ou contacter un technicien qualifi? pour obtenir de l'aide.
2/21/2023 1:08:30 PM • LG Heating &... • Answered on Feb 21, 2023
LG Ducted air-conditioner error CH12 - what does it mean?
  1. Check the wiring: Make sure all of the wires are properly connected and that there are no loose or broken wires.
  2. Check the control panel: Make sure the control panel is properly programmed and that all settings are correct.
  3. Reset the air-conditioner: Turn off the air-conditioner and unplug it for a few minutes, then plug it back in and turn it on again.
  4. Call a professional: If the issue persists, it may require the attention of a professional air-conditioning technician to diagnose and repair the problem.
It's important to address the error code as soon as possible, as it could indicate a malfunction in the air-conditioner that could affect its performance and efficiency.
2/13/2023 3:05:10 AM • LG Heating &... • Answered on Feb 13, 2023
LG LP076HD3A Packaged Terminal Air Conditioner PTAC, A/C & Heat Pu Logo
1 questions posted
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • LG Heating & Cooling
Most Popular Question
lg hotel ac heat ptac unit showing code
  • Heating & Cooling
