20 Most Recent
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
I want to know how
Download and install Nero Burning Rom program, open it, set in the up window the option CD/DVD, get to preferite, copy CD or copy DVD option, depends by what you need, set the speed 4x for DVD or 8x for CD for have a good copy quality, insert the original disk, it will copy it, then insert the new disk to burn.
6/30/2020 2:32:13 PM •
Acer...
Answered
on Jun 30, 2020
I have Windows XP and
Hi
Try to download VLC-mediaplayer from:Videolan.org and try with this program. and/or:
i allways use Mediaplayer Classic
http://mpc-hc.sourceforge.net/ this works really well for me
and plays ALL Media. also download and install FFDSHOW: http://www.free-codecs.com/download/ffdshow.htm (this is the codec for media files)
Good Luck
7/11/2019 8:13:48 AM •
Acer...
Answered
on Jul 11, 2019
My cd/dvd burner on laptop wont recognise blank dvd
You said that you are using Windows XP. So, you have an older computer. Have you looked in the Device Manager and verified that it can read DVDs. Older system so you might have a CD only drive in there.Check it out
3/8/2017 7:50:26 AM •
Acer...
Answered
on Mar 08, 2017
Bios CD-R/RW Toshiba SR-C8002
defective drive or dirty lense can cause this problem. And it could be a problem of mis-adjustment of the head (which will require factory repair).
7/3/2014 3:27:22 PM •
Acer...
Answered
on Jul 03, 2014
Acer 4520 cd/dvd driver problem
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer. This will surely help you resolve your issue. Good Luck!!!Thanks
12/19/2012 12:05:17 PM •
Acer...
Answered
on Dec 19, 2012
My acer aspire dvd rw
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
12/13/2012 1:20:37 PM •
Acer...
Answered
on Dec 13, 2012
My dvd rom dosent work
check cables,update driver & try to re-install it from device manager
10/5/2011 10:49:28 AM •
Acer...
Answered
on Oct 05, 2011
My Acer Aspire 5520-5912 laptop
Need to delete upper and lower filter.I had tjis issue before and the pc doctors resolved it.You can also contact them.www.thebestpcdoctor.comtel-877-407-9229
9/28/2011 7:34:19 PM •
Acer...
Answered
on Sep 28, 2011
My aspire 5742 burns dvd
OK when you boot up your computer does it says your DVD so so is workingif is not back up your drive in the BIOS or get a soft ware call or download from CNET call covert dvd and musics.....
9/24/2011 6:37:21 AM •
Acer...
Answered
on Sep 24, 2011
I have an acer aspire
Hi and welcome to Fixya,
What error message did you get when you tried to burn CD? Generally you can tell what kind of burner you have simply by looking at the drive. If it's a CD-RW drive, you'll see the word CD-RW or CD-R or the phrase Compact Disk Re-writable marked on the front of the drive. If it's a DVD burner, you'll see DVD-RW or DVD-R or DVD+RW marked on the drive. Most laptops today comes with a "DVD-Super Multi" which means it is DVD/CD Burner/Reader all in one.
Please post the error details here so we can provide more specific instruction. Thanks for using Fixya.
9/6/2011 1:59:54 AM •
Acer...
Answered
on Sep 06, 2011
Cd/dvd drive not working not
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
8/26/2011 3:24:53 PM •
Acer...
Answered
on Aug 26, 2011
Acer dvd writer not read
a motherboard disc the sound drivers could be on it
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this
helps
8/1/2011 12:49:56 PM •
Acer...
Answered
on Aug 01, 2011
I have a notebook 4520G
Hello there is no problem with the driver of your CD rom the problem is in your CD rom. Try to clean your cd rom with a piece of clean cotton. Gentle rub the cotton on the lens of your CD rom, then try to insert a cd if the problem is still there clean it again and again. If does not get by cleaning it is good to be checked by a electronic technician because maybe the lens have a problem or may need an adjustment to the lens of your CD ROm. In ejecting your cd rom there is a problem with your cd rom microswitch which is located inside your CD rom or the trigger of the microswitch is miss align. Hope this can help..
7/17/2011 6:25:27 AM •
Acer...
Answered
on Jul 17, 2011
I have acer aspire 4520
Your DVD Rom drive is faulty, you will need to go to a computer shop or an online auction site to buy one thats compatible with your laptop after you get this through the post on the back of your laptop will be a single screw with a picture next to it that looks like 3 Cd's by taking this screw out your DVD Rom drive will come out giving you access and to replace it.
7/7/2011 11:10:37 AM •
Acer...
Answered
on Jul 07, 2011
