20 Most Recent
Initial DTV-171 17 in. TV/DVD Combo Questions & Answers
Initial DTV-372
The cord can be tested to see if voltage is reaching inside the set, if you get any power or other light on front the cord is ok.
Initial dtv-171 tv/dvd
there is a box on the home of fixya.com that says enter yor zip code to find a repair man near you just follow the instructions good luck.
TV Remote
Try
www.remotes.com I have an Intial brand television and this is the only place that I could find that have them. I have had mine for over a year and it works perfectly!
Remote control
try to retrieve the cover of the universal remote, the codes are listed at the or at a small manual included.
How do I get sounds
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
