20 Most Recent Danby Premiere DDR5009REE 50 Pint Capacity Dehumidifier with 2 Fan Speeds, Electronic Controls, Adjustable Humidity Settings, Direct Drain Feature and 3,000 sq. ft. Coverage Area Questions & Answers
Compressor Works for a while Only On Initial Plug-in
If your machine is equipped with a humidistat it could be faulty and not sensing the humidity level accurately.
3/16/2017 10:34:49 PM • Danby Premiere... • Answered on Mar 16, 2017
What is rightsettingto set at
the general accepted Rh for the avg home is 70% Rh this is dry enough to not promote mold growth but wet enough that all your wood surfaces wounlt dry out and crack
10/23/2014 2:00:07 AM • Danby Premiere... • Answered on Oct 23, 2014
Zip tie stuck inside Danby dehumidifier
Not a problem, they are full of plastic.
6/14/2023 3:14:09 AM • Danby... • Answered on Jun 14, 2023
Dehumidifier doesn't turn on
The water in your sump pit needs to be no more than 2-3 inches, this is enough to keep your pump happy and make sure it works properly when you need it to. Equally, the pump should start to work when the water level is still 6-7 inches below the level of your floor. https://www.homoq.com/proper-sump-pit-water-level/
6/18/2021 4:49:02 AM • Danby... • Answered on Jun 18, 2021
My Danby dehumidifier leaks out
The drain tube or hole that drains into the bucket is probably clogged.
Turn the unit OFF and remove the bucket. Look in the cavity where the bucket was removed for a drain tube or drain hole. Using an 18" long plastic Zip Tie or something similar (No wire coat hangers) , that's appropriately sized to fit in the hole. Carefully feed the ZIP Tie into the hole or tube and thread it as far as you can. At some point the drain will curve, but you have to carefully get past this point. Once the Zip Tie has reached as far as it can, slowly pull it out while rotating it. This will loosen the clog. Once you have it half way out, be prepared for water to follow. This method should solve the problem.
6/26/2020 12:55:13 AM • Danby... • Answered on Jun 26, 2020
I am looking for a manual for a Danby dehumidifier model DDR070BBCBD8. Where would I find one
try searching for " Danby dehumidifier model DDR070BBCBD8"
10/28/2019 6:49:27 PM • Danby... • Answered on Oct 28, 2019
I would like to get an owner’s manual for a Premier Danby R410A Dehumidifier
try looking here and using a search engine next time. https://www.manualslib.com/brand/danby/dehumidifier.html
10/28/2019 6:22:41 PM • Danby... • Answered on Oct 28, 2019
Have Danby dehumidifier, turned on first time this season,fan & all displays worked fine, but compressor never went on. Removed back panel & compressor is very hot.
Be careful. i do not know. set at highest setting and let it run. while running, reduce setting to the lowest over a few minutes. at a lower setting you should be able to tell that the compressor has started. run it for 5 minutes, then unplug your machine. next, feel the cooling coils to see if they are very cold. if they are not cold, your unit needs to be serviced.
10/2/2019 5:02:43 AM • Danby... • Answered on Oct 02, 2019
Model Danby dehumidifier DDR70A2GP turns off after 30 sec. It has not been used yet this season to dehumidify clean finished basement. It is very clean and has worked well. Tech support was no help.
i don't know. my generic unit will do similar if i don't have the units moisture level set at a lower number. consider using your lowest setting as a test.
10/1/2019 9:39:25 PM • Danby... • Answered on Oct 01, 2019
Danby dehumidifier DDR7009REE about 10 years old, is it worth repairing if the compressor is shot?
No, these are throw away items. It will cost more to repair than getting a new one.
9/3/2019 1:33:06 PM • Danby... • Answered on Sep 03, 2019
Looking for a manual for a Danby Silhouette DDR505R Dehumidifier
Call or contact Danby to request assistance. Different model manual online: https://www.danby.com/products/dehumidifiers/ddr050beccdb/
5/1/2019 9:56:00 AM • Danby... • Answered on May 01, 2019
Dandy ddr70a2gp. Compressor not coming on
Ck the fuse ,relay,freon psi wiring & compressor clutch
1/7/2019 12:21:10 AM • Danby... • Answered on Jan 07, 2019
Why does my Danby DPAC9006 Portable AC fill up with water so quickly all of a sudden?
ac units work by removing water vapor from the air That accounts for the water that is getting into the collector now if the water volume is increasing , it can be from an increase in humidity of the air portable units have to have an opening ( window or door ) to pass out the hot air and that allows more moisture laden air into the room. Maybe the next unit you get is fixed so that all of the doors and windows can be kept closed
7/27/2018 11:02:45 AM • Danby... • Answered on Jul 27, 2018
Danby Premiere DDR5009REE 50 Pint Capacity Dehumidifier with 2 Fan Speeds, Electronic Controls, Adjustable Humidity Settings, Direct Drain Feature and 3,000 sq. ft. Coverage Area Logo
5 questions posted
Top Danby Dehumidifiers Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Danby Dehumidifiers
  • Danby Dehumidifiers
Most Popular Question
compressor works while only initial plug
  • Dehumidifiers
