20 Most Recent Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher Questions & Answers
0answers
My dishwasher has stopped cleaning plates
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101 kjh;lkhjk
9/29/2010 3:44:59 PM • Zanussi 18 in.... • Answered on Sep 29, 2010
Dishwasher going through cycle but water not
Heating Matrix faulty. This will need to be taken to a specialist for repair. or purchase new machine - would work out same cost.
2/16/2010 9:41:49 PM • Zanussi 18 in.... • Answered on Feb 16, 2010
Hi, my zanussi zdf221 dishwasher wont work, it
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
1/17/2010 6:25:54 PM • Zanussi 18 in.... • Answered on Jan 17, 2010
Zanussi zsf4123 heating problem
Look at the wiring going to the ends of the heater to see if there is an inline thermal fuse that blows when there is trouble in the heater itself. It is about the size of a regular fuse, but may be contained in some kind of covering. It needs to be connected with crimp type connectors, because soldering can ruin the new fuse. Do you have a wiring diagram for this unit? It would help to locate the source of your problem.
9/7/2009 8:48:56 PM • Zanussi 18 in.... • Answered on Sep 07, 2009
Water not heating
water not heating
1/26/2009 3:04:31 PM • Zanussi 18 in.... • Answered on Jan 26, 2009
Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
8/9/2008 2:20:56 PM • Zanussi 18 in.... • Answered on Aug 09, 2008
2answers
ZSF4126 - where do i put rinse aid!?
that dial with numbers is the flow rate for the rinse aid, just to the side of that there should be a little hole, it maybe under the flap where you put the powder, open the door fully, open the flap, find the little hole and pour rinse aid in there it should only hold about 1 to 200ml ( a small cup full? ) the dial should be set about halfway hope i have helped if so rate me please
3/5/2008 9:21:13 PM • Zanussi 18 in.... • Answered on Mar 05, 2008
2answers
Zanussi DE4744 not heating at all
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat; https://behealthyideas.com/ <ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
1/18/2023 11:10:53 AM • Zanussi... • Answered on Jan 18, 2023
Zanussi ZDLN1512 Dishwasher Anti Flood Warning - How can I fix?
If it is new, it is under warranty and if you try to fix it, it will void the warranty. The water in the flood tray comes from the machine itself, normally from hoses or on an older machine pump seals. Page 17 refers and confirms https://manualzz.com/doc/53457617/zanussi-zdln1512-user-manual Call for warranty service to fix the fault free of charge.
8/21/2022 4:41:25 PM • Zanussi... • Answered on Aug 21, 2022
2answers
Zanussi ZDF231 top spray arm is not turning, is it a pump fault?
input to pump clogged output clogged pump bad or just dirty inside. leaks end to end that path, In and output.
8/2/2022 11:19:44 AM • Zanussi... • Answered on Aug 02, 2022
Zanussi ZDF26001XA code .30 anti flood device. how do i fix it without calling a mechanic?
Under the base of the machine, above the floor there is a tray with a sensor in it and that is what triggers the Flood Error Code. So the machine needs to come out, the back or side panel removed and the tray thoroughly dried. You also need to find where that water came from. If the salt container is in the base, it may be leaking if you were breaking up the salt.
11/30/2021 4:42:10 PM • Zanussi... • Answered on Nov 30, 2021
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault. Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle". For example: one flash = i10, two flashes = i20 ..........and so on So, count how many times LED "end of cycle" flashes and you will know the error code. Dado
9/18/2021 8:05:04 AM • Zanussi... • Answered on Sep 18, 2021
Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher Logo
Popular Tags
24 questions posted
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dishwashers
  • Zanussi Dishwashers
Most Popular Question
  • Dishwashers
