20 Most Recent LG LFX25991ST 24.6 cu. ft. Counter-Depth French Door Refrigerator with SpiProtector Glass Shelves, Humidity Crispers, Glide N Serve Drawer, 3-Tier Freezer and External Ice/Water Dispenser Questions & Answers
Turn it off, remove everything and clean it
LG LFX25991ST... | Answered on Mar 15, 2013
You would have to pull the ballast transformer out.
Pull the light fitting out.
Fit a new socket.
Run the mains wires that went the ballast transformer to the new socket.
Air Purifiers | Answered on Jan 10, 2020
Support at Guardian
https://www.guardiantechnologies.com/support
From your previous question: the Replace HEPA filter light wont go off.
Note: When you add information to a question, please use the Comment or Edit feature to add it to the same question, rather than opening a new question, because the new one has no link to the older one.
Air Purifiers | Answered on Nov 04, 2019
Check to see if there is a crack in the ceramic plate. If there is any type of disturbance where the metal is glued to it or you don’t have both leads on the metal it will not work
Air Purifiers | Answered on Oct 26, 2019
Where can one get a new bulb ballast for the UV801?
Air Purifiers | Answered on Jul 17, 2019
Google IT JUST AS WE COULD
Air Purifiers | Answered on Apr 11, 2019
I would verify that all the parts you removed are properly seated back in their exact locations.
There is undoubtably a safety switch that is not properly closed.
A door, a panel, or a latch that is not properly seated and closing the safety switch is probably the cause.
Air Purifiers | Answered on Mar 04, 2019
LG LFX25991ST 24.6 cu. ft. Counter-Depth French Door Refrigerator with SpiProtector Glass Shelves, Humidity Crispers, Glide N Serve Drawer, 3-Tier Freezer and External Ice/Water Dispenser Logo
7 questions posted
Top LG Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a LG Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
LG Air Purifiers
  • LG Air Purifiers
Most Popular Question
refrigerator
  • Air Purifiers
