20 Most Recent Emerson Icp Heil Tempstar Fan Motor K55hxeml-7422 1/3 Hp Arcoaire Comfort Maker Questions & Answers
I have an old lux500 thermostat in replacing it with Emerson sensi touch smart thermostat. Do I need to change any wiring?
Probably, see the wiring directions, or call an HVAC technician.
11/1/2023 8:16:19 PM • Emerson Heating... • Answered on Nov 01, 2023
2answers
Changing thermostat from old Lux 500 to Emerson sensi touch smart thermostat. Is the current wiring compatible with both?
you are the only one who knows how many wires you have and hvac. here is the manual and you can look at wiring diagrams. https://www.luxproducts.com/wp-content/uploads/2017/07/tx500_manual_en.pdf
10/29/2023 9:00:14 PM • Emerson Heating... • Answered on Oct 29, 2023
Emerson thermostat 1f88ez-0251 Flame icon is flashing how do I fix this?
you can lower temp setting ,or leave it alone it is normal here is a link to instructions copy and paste https://climate.emerson.com/documents/thermostat-1f86ez-0251-instructions-es-es-1570244.pdf ..
2/4/2023 3:03:55 PM • Emerson Heating... • Answered on Feb 04, 2023
What does it mean when flame icon is flashing on an Emerson thermostat?
The Flame icon ( ) will display flashing to indicate that the Aux system is operating. Press to adjust the thermostat below room temperature. The Aux heating system should stop operating.
2/4/2023 3:00:39 PM • Emerson Heating... • Answered on Feb 04, 2023
How to stop a thermostat from self setting
Different Nest thermostat models give you different options for setting up a temperature schedule that meets your needs:
  • Auto-Schedule (Nest Thermostat E and Nest Learning Thermostat only)
  • Basic Schedule (for Nest Thermostat E only)
  • Quick schedule (Nest Thermostat only)
10/24/2022 12:04:52 PM • Emerson Heating... • Answered on Oct 24, 2022
Emerson motor K48ZZENH3516 wiring diagram
try this link there is motor with data plate. copy and paste https://www.ebay.com/p/1482474862 .
8/23/2022 4:51:06 PM • Emerson Heating... • Answered on Aug 23, 2022
I have an Emerson quiet Kool rv air conditioner serial #18F820463 model #EQK1350-G WONT PUT OUT HEAT
the heater is an option was one installed ---if their was need to check element / and control circuit fuse--relay circuit http://bryantrv.com/docs2/docs/operating/qcparts.pdf this link shows wiring and circuity for the heating part of system
11/8/2021 12:56:49 PM • Emerson Heating... • Answered on Nov 08, 2021
I have a Code EH on my Emerson quiet Kool EBD30E1.Means what?
contact Emerson and ask them we do not have all error codes for every product world wide
11/6/2021 3:43:53 PM • Emerson Heating... • Answered on Nov 06, 2021
Emerson K55HXLKC 3758 WIRING DIAGRAM
Contact Emerson directly to request the wiring diagram.
9/7/2021 2:13:27 PM • Emerson Heating... • Answered on Sep 07, 2021
3answers
What run capacitor is used on a Emerson LR63596 compressor motor. The number on the capacitor is not ledgable
Most motor capacitors are actually start capacitors. There are motors that use both a start and a run capacitor, usually combined into a single package but such motors are fairly rare. As it isn't possible to identify the capacitor value you either need to approach a motor specialist for advice or to order a replacement as a spare part for either the machine or the motor from the manufacturer.
1/6/2021 4:45:35 AM • Emerson Heating... • Answered on Jan 06, 2021
How do you bypass Emerson Comfort Alert Commercial Diagnostics. This specific unit keep having error #8. (Welded contactor).
Don't bypass electrical contactors, replace it. Bypassing it will burn out the switch and possible cause a fire. A switch or circuit tells the contactor to supply power and a solenoid smashed the double pole contacts together, 2 negatives and 2 positives. The switch doesn't carry the power, the contactor does. It is a Protection Device https://www.emerson.com/documents/commercial-residential/comfort-alert-diagnostics-for-commercial-applications-en-us-160794.pdf https://climate.emerson.com/documents/comfort-alert-user-manual-en-2884458.pdf There is a video here. I haven't watched it https://www.google.com/search?q=Emerson+Comfort+Alert+Commercial+Diagnostics
11/12/2020 5:32:50 PM • Emerson Heating... • Answered on Nov 12, 2020
My Emerson thermostat reset the temperature from 18C to 21C on it's own. It was in temperature hold mode when it did this.
maybe you had a temporary hold rather than permanent hold. turn the temp back with permanent hold.
5/27/2019 2:58:13 AM • Emerson Heating... • Answered on May 27, 2019
2answers
Why does my Emerson thermostat keep changing to auxiliary heat I want it to stay on heat
system is likely going into defrost mode. this is necessary for heat pumps in extreme cold weather
1/19/2019 1:26:51 AM • Emerson Heating... • Answered on Jan 19, 2019
Emerson Icp Heil Tempstar Fan Motor K55hxeml-7422 1/3 Hp Arcoaire Comfort Maker Logo
0 questions posted
Top Emerson Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Heating & Cooling
Most Popular Question
emerson thermostat keep changing
  • Heating & Cooling
