20 Most Recent
Invacare Pronto M61 with SureStep Rehab Version Questions & Answers
Reset of dash lights RE. Potentiometer -
hi John, the tiller display you got on that scooter , if all of the lights are coming on even when the battery power is low sadly is a faulty component, they are cheap to repair and is now a common problem because they quite old ..
Regards
Rob
Invacare Leo back wheels seizing up and also hard to push without locking in freewheel mode
hi Helen, firstly the scooter will lock up after a couple of metres , that is by design to stop you rolling down a hill etc ..
Now if the scooter is hard to push even in freewheel, means the brake has either decided to seize (lack of use , been in storage ) or has become damage. The mechanism for releasing the brake has become damaged . brake removal recommended then try to push the scooter , if it 's okay then its the brake if not , it could be the coupling between the motor and gearbox has failed or the gearbox itself has a issue,.
Regards
Rob
Are both lights supposed to be green i have 1 red 1 green on my battery for my invacare scooter
Mine is an Invacare M51 Pronto Surestep with an onboard Winsunny battery charger. My charging lights are solid red and green/ yellow. Depending on if it is charging or not. What kind of charger do you have?
I have to replace my charger because it is not working. My green light is staying green while charging even though my joystick is showing my batteries are depleting and I just got new batteries. sigh.
