20 Most Recent LG Dehumidifier LD650EAL Questions & Answers
I had the same problem. For me the fix was to take all the covers off, remove the bucket switch, clean the contacts on the switch, and i poured alcohol all over the switch and repeatedly pressed on the actuator . I dried it all off, put everything back and it worked again like a charm.
LG Dehumidifier... | Answered on Jun 03, 2018
Could be low on freon or humidestat is bad..
LG Dehumidifier... | Answered on Apr 02, 2015
It appears as if the water may not be flowing through the hose.
* When you use a hose the unit must be located near the drain. If the hose is to long the water will not flow freely and cause the water to back up in the hose triggering the bucket full.
* If the unit is lower or the hose runs up hill even the slightest incline will cause the water not to flow backing up to the machine
* Hose must remain flat and in a down hill flow to the drain if you are running a longer hose than recommended. If you are have a long distance to run the hose elevate the dehumidifieer by placing it on a stand, milk crate, anything that will hold the unit. Be sure it is large enough and strong enough to support the unit to prevent it from falling. This will help siphon the water from the unit and prevent any water to back up the unit.
* If your using an old hose make sure there are no kinks and water flows freely through the hose. Any kinks or type of pinch in the hose will cause the water to back up
I hope this helps resolve your issue. This is the most common mistake when using a hose.
LG Dehumidifier... | Answered on Nov 30, 2013
Hello everyone, can someone please tell me what is error code CH10 on lg dehumidifier please?
Thank you
LG Dehumidifiers | Answered on Jul 25, 2019
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
LG Dehumidifiers | Answered on Nov 28, 2018
  • Bucket incorrectly installed
  • Unit not level
LG Dehumidifiers | Answered on Jun 25, 2018
LG Dehumidifier LD650EAL Logo
11 questions posted
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
bucket full light but no water in
  • Dehumidifiers
