Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Question edited for clarity, correct order and model detail (123 - DOT -12345).
There is one site that says it has the 25804 model, but you have to register. Manual are normally free from the Sears Kenmore site. Check the model number is correct.
https://www.google.com/search?q=Kenmore+129.25803+dehumidifier+manual
580.5451 appears to be the dehumidifier model #Contact Sears online or by phone:https://www.searspartsdirect.com/model/3gdb2g701p-000582/kenmore-58054351900-dehumidifier-partshttps://www.searspartsdirect.com/search?q=580.54351
I would suspect the cooling coils have leaked the freon and aren't cooling enough to condense the humidity into water. These units aren't really made to repair unless it's a switch or humidity sensor. The cost to have the leak fixed and freon reloaded would exceed just buying a new unit.
First I'm not a Kenmore Tech.
* Check your warranty and call for service.
*** The following is for information only ***
* I had one of these dehumidifier. I've used both the drain bucket by itself and well as the hose attachment.
* the bucket has a hose cap at the bottom to allow a typical garden hose to be attached. Remove the cap and attach the hose.
* If you want to use just the bucket then you will need to remove the garden hose and re-cap the bucket. Otherwise the water will just drain on the floor. You can find a replacement cap at any hardware or garden shop.
* There is a sensor switch under the drain bucket. This senses if there is a bucket present and it will turn off the unit once it's full of water.
*** The bucket must be present for this dehumidifier to work ***
* You must place the bucket in the right position for the unit to come on. The attached hose must move freely up and down to prevent the bucket from being weighed down and turning off the unit as it thinks the bucket is full. Lifting the hose a bit up and down will give you an idea if it's too heavy.
* Final; there is an adjustment knob in the front to determine how dry the air you want. I've used this unit to dry out wet carpets in a room so it's set at max and usually takes about 1-2 days to dry out a room (in Hawaii with 60% humidity). You will need to set this up and adjust it for your purpose.
Aloha, ukeboy57
I found the following vids on you tube;
https://www.youtube.com/watch?v=VhLv0xR9-Aghttps://www.youtube.com/watch?v=EmWuaIG8fS8https://www.youtube.com/watch?v=XOh4BztkIEohttps://www.youtube.com/watch?v=Zb2rj-xWE9Ahttps://www.youtube.com/watch?v=Zb2rj-xWE9A
