20 Most Recent Apple Epson Perfection 2450 Photo Flatbed Scanner Questions & Answers
I hav got Mac OS X. Version 10.7 2 x 2.8 GHz
There is a good discussion on the various options you at https://discussions.apple.com/thread/3212947?start=0&tstart=0 Hope this helps.
2/1/2012 1:04:12 PM • Apple Epson... • Answered on Feb 01, 2012
How open case to Epson Perfection 2450?
go to Epson.com tghey should have the solution if not email me at [email protected]
2/5/2009 8:00:54 PM • Apple Epson... • Answered on Feb 05, 2009
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details: 4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions. Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work. No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector. Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others. You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
11/19/2023 5:44:49 PM • Apple Office... • Answered on Nov 19, 2023
Oce tds 860 error code 01101
Check if the fan on the Op panel side of the machine is running. Ensure the intake on left hand side of machine isn't blocked. Ensure rear vent on right hand back of machine is not blocked.
4/25/2019 2:44:15 AM • Apple Office... • Answered on Apr 25, 2019
WiFi connected to Apple MacPro
Have you set up the printer to print wireless? If so, if you have the computer and printer setup to work together, you should be able to turn the printer on and leave it on and print one job at a time. After it prints one job, it will stop and just be ready and waiting for you to send the next job. No need to turn off between jobs.
3/19/2018 1:50:46 AM • Apple Office... • Answered on Mar 19, 2018
,Printout has white horizontal streaks using win10 or my mini iPad, printer ok using Apple computer, while printing text. Color cart. Showing low ink, but was just replaced
When the ink is run past low (to empty) the print head can get damaged. You can also try 2 consecutive DEEP CLEANINGs .. See 'maintenance' in printer driver under advance setting s
1/6/2018 5:28:51 AM • Apple Office... • Answered on Jan 06, 2018
Why my pc is switched on but the monitor screen is blank?
Was the monitor turned off separately from the computer? The monitor does have it's own on/off switch. If it's all connected to a surge protector both would normally turn off at the same time.
10/21/2017 4:45:51 PM • Apple Office... • Answered on Oct 21, 2017
How can I connect Apple Mac to printer via new BTHub5-7XH2?
I suggest connecting the ethernet port on your Mac to the router and the router to your printer. You don't mention what printer you have (that would have been helpful) but I'm assuming it is networkable. Otherwise bypass the router and use a USB cable to connect it directly to your Mac in the usual fashion.
7/25/2016 10:53:27 AM • Apple Office... • Answered on Jul 25, 2016
How to connect apple mac to printer
use a usb cable
3/26/2016 12:19:43 PM • Apple Office... • Answered on Mar 26, 2016
Hp driver f2492
Some older scanners are not supported by the newer versions of Apple OSX. This can be a real problem for owners of older printer/scanner equipment and windows 8/10 has driver issues with older equipment also. HP is a great printer or scanner. They make a universal print driver and a universal scan driver which I have installed both in my macs and in my windows machines (I have both OSX and Windows machines at home and at work) The universal scan drivers and universal print drivers may work on your unit. Also you may have to assign your printer a high static IP address and tell the computer and driver where to find it, as sometimes automatic pairing is not possible. Example... Your router IP address is 192.168.1.1 and it passes out DHCP addresses from 50 to 100 (192.168.1.50 to 192.168.1.100). You can assign your printers in the house of office static IP address starting at .201 then .202 .203 etc... Tell the driver you know the IP address and enter 192.168.1.201 and the driver or HP universal driver will find the printer and link up no problem.
3/20/2016 7:25:19 PM • Apple Office... • Answered on Mar 20, 2016
Apple Epson Perfection 2450 Photo Flatbed Scanner Logo
Popular Tags
3 questions posted
Top Apple Office Equipment & Supplies Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
k24674
Kolbrun...
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Office Equipment & Supplies
Most Popular Question
hav got mac os x version 10 7 2 x 2 8
  • Office Equipment & Supplies
