20 Most Recent
Apple Elgato EyeTV (T5301LL/A) Video Capture Questions & Answers
Elgato EyeTV (T5301LL/A) Video Capture: I have an old camcorder - with only a yellow video...
If you have just one Audio Out RCA jack then the camcorder only recorded in MONO, so all you would need to do is either plug the wire coming from your single Audio Out jack into the left or white input jack of your Capture Device which may have an option in the software program to set it to recieve audio in MONO, or you can buy a RCA Jack Splitter that goes from a single Female RCA jack on one end and 2 Male RCA Jacks on the other end. Then you take the end of the Splitter with 2 plugs and plug one of them into the White Jack and the other into the Red Jack on your Capture Device, and the other end with just one plug should plug into the cord coming from the Black Jack on your Camcorder.
Will not connect to wii
if you do not have the latest updates for the devices i think you do not have the Hybrid for Wii and XBOX
http://forums.macrumors.com/showthread.php?t=494829
http://store.apple.com/us_smb_78313/product/TS588LL/A
How do I install apple products
Assuming your tv has an HDMI port, you simply need an HDMI cable from the Apple TV to the LG. On the LG, choose the HDMI input you connected to, and follow the prompts to set up the Apple.
I have a MAC and use Safari as my browser. Why can
it might be your Flash player. Just update your Flash player to latest one. It depends on your viewing time, also. If a lot of them watch same video at same time, it slows down the server or just freezes it.
How to activate Apple TV from dish tv how do I get the activation code
to put in to watch womens basketball
Hi Donna,
I did some research and it was difficult to find an exact answer online searching some forums and FAQs on websites.
I contacted DISH through their chat feature and they recommended you contact their support at 1-800-333-3474
- in general you should be able to go inti the Apple TV settings and pick your “provider” to “marry” the services together.
Certain channels may require separate activation codes such as HBO GO where you have to actually go to www.hbogo.com/activate to complete the registration
I no longer have fios, how do I change my Apple TV app to direct tv?
To switch the tv provider in iOS: open the settings app, then “TV Provider” there you can log out, and select what iOS apps have permission to access that provider login.
In Apple TV: Settings app, Accounts, then under ACCOUNTS select TV Provider.
For DIRECTV apps that you can download to iOS or tvOS make sure you get the right one. There is Directv app for controlling the satellite receiver and accessing account. The. There is the digital device based DirectvNOW app, which is used if you do not have a receiver and just stream content only.
