20 Most Recent
ASUS Terminator P4 PC Desktop Questions & Answers
Sound drivers
Click
start control panel administration tools computer management device manager
scroll to sound video and game controllers you might see a yellow question /
exclamation? ! mark or a red X Right click to reinstall drivers
If
your computer came with a motherboard disk the drivers could be on it
or
you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a
free driver solutions
which will automatically search for and find the
correct driver
You
will have to update every driver individually once you update you might be
asked whether you want to restart or make a system restore point.
Click
no to both of these then continue updating each driver free then restart once
all of the drivers have been updated.
It might take some time being free
also
http://download.cnet.com/2000-20_4.html
Just type in what you want or need be specific you
might have to try a few times to get it right.
Tick in either the all software or the windows
software box.
IE: Motherboard name sound
drivers
Mising audio driver
i do have 5 ways to get drivers : 1. you have to go to the manufacturer website and download the driver2. use microsoft update......now for your problem copy to your brouser this link:http://support.asus.com/download/options.aspx?SLanguage=en&type=1and click start at model automatic detect, after detection it will show the drivers which you needRemember to rate my answer, we work hard to help you for free
I want to install an
Hi,Try to clean your video card by using an eraser,then plug it again,If the problem still exist,try to use other video card,but still not working the problem would be your motherboard.thanks
Trying upgrade from PC2100 to
Look to see if there is a jumper setting on *********** board for the cpu speed or there might be a speed setting in your cmos. Are you sure your motherboard will accept a faster cpu
How do I open the case to change the power supply?
Do you have a latch on the back? If so, pull it and your systems protective covers will fall to the ground! If not, you will have to unscrew one of the side panels.
I am not responsible for any damage done.
-K.R.
"I know what I know because I know what to do!"
Pc wont power up its gone dead,checked all power
Check to see if you fan in your PSU is spinning around this is a good quick check the power supply might be fried on either the 12V or 5V sides you can get a PSU checker cheap on the internet from japan for about £3 dont get one from Maplins theres are about £20.
Next does your HDD led on the front of the PC start to flash if not there is not power there either.
If the answers to both these checks are NO you will need an new power supply, costs range from £30 upto £60 for high power units however a 300W unit should suffice for most PC's however it does depend upon how many perhiperals or drives you have attached as all take some power fron the unit.
LOL
Motherboard drivers
http://support.asus.com/faq/faq.aspx?SLanguage=en-us HAVE FUN HERE AND FIND EVERYTHING YOU NEED
Hang & Restrarting of PC
Change the power supply, i.e. the SMPS with a new one of the same rating and make sure all the power & data cables are snug tight in their respective slots. Also take out the RAM, clean it and replace. Try to remove any dust if possible from all the sockets/connectors...........sodeep
I have a Sony Unit
I'm not exactly sure what you are explaining but to disable in Windows go to: My computer: Properties: Hardware: Device Mgr: Graphics Card and for the one listed that is not your AGP card click: Disable This Device. It's just that simple. Also, in some BIOS,maybe all, there is an AGP: enable/disable box. This of course should be enabled.
Driver
go on to google and type in the driver you are looking for and they should give you a link to follow. Most drivers are available on the net.
